  New Posts New Posts RSS Feed - scoop compatible drivers...
 Post Reply Post Reply Page  123 25>
knet94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Topic: scoop compatible drivers...
    Posted: 13 February 2024 at 12:14am
Kid Creole (Mykey) thinks very highly of LaVoce.
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2024 at 3:32pm
I have used two of their models currently, both performed as expected. There are even some more in depth reviews of for example the 214.50 on databass. Would not expect any different from the 184.3, if it will do the job in a scoop is another subject.
PS: they are designed in Italy and manufactured in China (just as the advertise), so not your standard cheap China driver.
_Natty_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2024 at 3:20pm
i heard something else that's from them paper looks great but in fact poor chinese driver. someone try to sell it as italian manufacturer, trust me. happy if with this unit they change the mood!
Edited by _Natty_ - 12 February 2024 at 3:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2024 at 2:32pm
Originally posted by _Natty_ _Natty_ wrote:
forget about it, the italian name should not trick you. chinese 100% and to me sounds so bad. never heard this specific unit.
Nobody is being tricked by the name. its not a secret where they make their drivers. Second, how can you say it sounds bad if you do not have any experience with the driver?
Post Options Post Options   Thanks (0) Thanks(0)   Quote _Natty_ Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2024 at 11:29am
Navanor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Navanor Quote  Post ReplyReply Direct Link To This Post Posted: 17 November 2022 at 1:08pm
Hi everybody,
Is the Lavoce SAF184.3 a good choice for a scoop? I'm planning on building 4 of them
Resonant frequencyfS30Hz
Electrical QQES0.34
Mechanical QQMS6.70
Total Q factorQTS0.32
Suspension equivalent air volumeVAS245litres
DC resistanceRE5.8Ω
Minimum impedanceZmin7.2Ω
Voice coil inductanceLE2.1mH
Force factorB·l28T·m
Suspension mechanical resistanceRMS7N·s/m
Suspension mechanical complianceCMS110µm/N
Moving massMMD219.8g
Moving mass (including airload)MMS250g
Surface of the diaphragmSD1225cm²
Effective diaphragm diameterØ39.5cm
Maximum linear excursionXmax± 13mm
Excursion limitXlim± 22.3mm
Displacement volume at XmaxVD1592.5cm³
Efficiencyη₀1.7%
Efficiency bandwidth productEBP88
Cheers,
Nathan
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2022 at 7:09am
Originally posted by alehmarques alehmarques wrote:
Yes I did, but it is already on the list of compatible drivers... I mentioned the DS100 because nobody talk about it... there is a hot deal on Bluearan right now (may 2022) only 275GBP 18DS100.
I see, that makes sense Clap
Daddy Culture View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daddy Culture Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2022 at 9:00pm
Edited by alehmarques - 20 May 2022 at 9:01pm
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2022 at 8:24pm
Just tested the 18DS100 from B&C on Polar Bear Scoop... very impressive driver and should be added to the list of compatible drivers.
You might also want to try its bigger brother.......Evil Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daddy Culture Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2022 at 6:02pm
Edited by alehmarques - 18 May 2022 at 6:03pm
RealitySound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2021 at 11:18pm
Isn't that the driver Tony was putting in most of his cabs?
When you gonna send me some $$ mate ?
paulus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulus Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2021 at 11:04am
one of the best speakers i have heard lately is the b n c 18sw115 i know its been out a while but wow what a beast ,obvz for med to large chambers  by default because of the depth ( 226mm from back of mounting flange ) but  can do a return on the throat to load it a bit more if needed , we ab tested with 1852s and the 1852s blew up, not in the same league, the b and cs lasted all day as was a afternoon session 2 till 11 on the night :) amp was a itech 12k with 2 a side 32 amp feed limiters set just under clip but no clipping
Edited by paulus - 15 September 2021 at 11:12am
TRENDSETTER SOUND SYSTEM
