  New Posts New Posts RSS Feed - Comments on system plan
Timber_MG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Topic: Comments on system plan
    Posted: 01 October 2004 at 2:20pm
I am in the process of thinking up my system and would like some feedback on my current plans.
System plans (per side)
3-4x Folded horn (40Hz -140Hz)
2 x horn-Top (140Hz – 16kHz)
As P.Audio have a distributor here in SA, I was thinking of using their speakers for the Sub and Mid. I will try and source Oberton 1,4” drivers for the Top end, perhaps on a Selenium HL14-75 SLR with adaptor or a conical waveguide of sorts (40 degree horns are a little rare)
4 x C18-600EL/600LF in 40Hz folded horns
M=0.55 St = 590 Sm = 6000 length 2.1m, VB = 60l
1 or 2 PAP Porn horns per Top (2 of) loaded with SN-12B
Oberton 3672 driver on narrow dispersion horn/waveguide, cross 1k5 or lower.
As money is a huge concern, amping will have to be Behringer EP2500/EP1500 for now (money is at a premium here) and crossovers will likely be the Diverack PA or the Behringer Ultradrive.
If the Horn-tops turn out to be too costly, I am thinking of a 15”/1.4” similar to the X15 for tops, which could later be used as monitors/near-fills. I might start with these15/2 tops and move on the horn tops as I progress. The 15/2 Boxes would then serve as near-fills and stand in at smaller events. I was also thinking of a 12”/1” and a bass-reflex single 18 (C18-650EL) as a mate wants a party system to go on tour to Mozambique with.
Application for the system would range from out-door concerts (where I’d hire the other equipment), tents to mobile-disco events. I am doing this with a mate who is a free-lance sound-engineer and I have some contacts to the local Radio station who organize a fair number of events. Music would be anything from hip-hop, techno through to rock and metal or acoustic (basically anything). I would like to get the system ready in time for a new-year’s bash.
Your harshest criticism and alternate driver suggestions are most welcome
Martin
PS: this would double as my Home theatre system when in storage ;-), driven my my SB Live! and kX drivers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2004 at 4:22pm
Hi.
I'm just curious, why you have your mids cutting off at 140Hz.
Why not  120 - 100 Hz on the mids, and, 120 - 100 Hz on the bass?
Best Regards,
loophole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote loophole Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2004 at 4:51pm
elliot: (correct me if im wrong martin) because the porn horns won't go down to 100Hz. If he's using 40hz bass horns, i'd be very surprised if they didn't sound pretty good right up to 160-180. i've found the porn horns sound best crossed at about 140Hz, below that they just can't equal the punch of hd15s (and certainly not of 4x18" horns). how big's the diaphram on that oberon by the way?
Post Options Post Options   Thanks (0) Thanks(0)   Quote loophole Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2004 at 4:53pm
(1.4" exit i know, but you mentioned a larger diaphram or something a while back....?)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2004 at 4:56pm
Thanks for the input.
The Mid horn is speced to go down to 130Hz (dunno under what conditions) and is pretty big as it. Obviously the lower the x-over the better, but then the mid's get a whole lot more of the mid-bass and the tops might run at their limit sooner. This is one of those things that one'd find out when one hears the completed system, as folded horns are said to be a bit unpredictable going from design to practice.
The sub would be similar in design to the Martin Audio WSX, though I am considdering a snail fold (difficult with an 18" driver). As an alternative, I could use an Oberton 18" driver with 12mm x-max (@10% distortion) and BL of 27 but cost and especially the difficulties involved shipping these things makes life difficult. Beyma is an alternative, but for the money I recon P.Audio is a good deal.
Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2004 at 5:05pm
@ loophole Yeah, The 1,4" is very low distortion and it's availability on the German market is highly anticipated. It's a 3" diaphragm is made out of a sandwich Mylar material which gives it good response out of 14-15k. If I wanted to go all-out I’d Use the BMS 4592 co-ax which is a true monster, but the 1,4” is a good value and was highly praised for it’s sound at the PLS. It’s crossed at 700Hz in the Oberton T212 top (2x 12” horn-loaded) so it should do fine crossed higher up. Unfortunately the matching 1,5” porn horn wouldn’t quite fit, but a conical horn shouldn’t be too difficult to have made out of fibreglass.
As I don’t have much experience doing larger events, how many people would such a system be good for outdoors?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Elliot Thompson Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2004 at 5:10pm
Thank you loophole, and, Timber_MG.
It makes things more clear.
Best Regards,
Post Options Post Options   Thanks (0) Thanks(0)   Quote loophole Quote  Post ReplyReply Direct Link To This Post Posted: 01 October 2004 at 10:44pm
Originally posted by Timber_MG Timber_MG wrote:
a
you could even try turning the flare from a nice lump of hardwood ;)
personally i wish i could keep our system unpainted, (my 'carpenters taste' i guess...), but realistically its not very practical and the others involved have gotta have their say too
i haven't done any large outdoor events, but even so i always find it interesting that people can put definitive answers on what's 'enough' for a certain number of people. it makes sense in the conference/pa context, but when you're playing music it really varies hugely - on the type of music, and whether people are sitting listening, or dancing around or.....etc
and with certain types (dub for example) i dont think there is such thing as 'enough' ;)
but at a guess: 200-400?
interesting you mention that mylar sandwich construction. rog mentioned some new drivers which use a mylar-titanium composite, but instead of a sandwich construction, the material used varies across the radius of the diaphram, allowing the high frequencies to be produced with clarity but still keep the SPLs up near the x0ver freq. perhaps a solution at last for those of us stuck without supertweeters
how much are the oberton tops selling for?
joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 02 October 2004 at 2:25pm
Let’s for the numbers game keep to legal levels ;-) I was reckoning with about double your estimate, but as you say this varies strongly bassed on the application. Locally, I have seen smaller system serve crowds of 400, but then things are different here.
The Oberton Top as displayed on the website is the old model which used the BMS co-ax. The new model double 12/1.4 (T212) sells for 1420 Euro’s plus VAT + shipping from Bulgaria for countries not served by an Oberton distributor. They re-designed the HF section and made the whole cabinet look 10x more professional. It's a 60 degree horn though, so stacking multiples may become and issue.
Apparently, both Oberton and BMS are produced and engineered in Bulgaria, just BMS have their HQ in Germany. Both seem like very good manufacturers and provide good value (even if they’re not always cheap)
Regards
Martin
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2004 at 1:47am
I don't think that BMS is engineered in Bulgaria, as they sold their 4590 and 4550 (and below) years before the factory in Bulgaria was built.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timber_MG Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2004 at 3:19pm
Whoops. Peter from Oberton must have been fibbing then.
JD01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD01 Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2004 at 8:34pm
Maybe they do some research there too....
