  New Posts New Posts RSS Feed - 186 & 1850 used together.
AM55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AM55 Quote  Post ReplyReply Direct Link To This Post Topic: 186 & 1850 used together.
    Posted: 01 August 2013 at 8:49pm
That's why I say ish, I would be looking to cross out after 110. The higher up you get the worse the honk.
b grade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote b grade Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2013 at 7:24pm
I use mine a little higher than that.  I typically go to 125 with my 1850s.  They sound fine, though I do generally reduce a little bit of the upper part with parametric, as it gets really loud up high and overcomes the low end.
AM55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AM55 Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2013 at 6:21pm
1850s and 186s shouldn't be used above 110Hz ish. Not many DIY folded horns will reach up to 210 and still sound good.
Edited by AM55 - 01 August 2013 at 6:24pm
K M Sound System View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K M Sound System Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2013 at 6:08pm
Why not just build more 1850's?
4 running sub
2 running kick
+ your tops.
Then you dont have to worry about making sure your not mistaking the 186's for 1850's if they have the same style bracing.
and you wont have to worry about the time alignment or phase being an issue.
Dub-Sidious of Kollective Mindz
ClackS02 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClackS02 Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2013 at 12:10pm
im guessing some delay would be required on the 186..... what do other people think?
____________________
-Steve C
-DubRoach Productions
WILLIAM12345 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WILLIAM12345 Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2012 at 1:05am
yeah there the same size but the horn length is longer on the 1850. i reckon the 186 should sound perfect onto of the 1850
surly someone on hear has tried it
RealitySound View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RealitySound Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2012 at 12:46am
 I thought the only difference between the 1850/186 horn was the size of the rear chamber...........if this is true then the time alignment between the cabs should be the same.
When you gonna send me some $$ mate ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WILLIAM12345 Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2012 at 12:14am
just curious if anyone has used the 186 horn with the 1850 horn together in the same stack and weather it would sound ok .
i have 4 1850 horns and plan to put a pair of 186 horns on top playing  90Hz to 210Hzn. this way the 1850s are doin less work.
someone told me 1850s nd 186 bins phase bad but surly if they are running diff frequencies they will sound fine together
thank help is much appreciated
