  New Posts New Posts RSS Feed - Crown iTech series any good?
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Topic: Crown iTech series any good?
    Posted: 29 January 2019 at 12:27pm
New question about the I-tech.
I've searched the internet to find more about the available limiting but have one question about the average power limiter. I suspect these are not the same as the powersoft counter part, also looking at the limiting for their JBL products I can't get any confirmation, knowing they rate the transducers differently.
Drivers used with current limiting:
BMS 18S430V2 126 Vpeak 300 Watt APL
B&C 15NW76-8 85 Vpeak 150 Watt APL
RCF ND950-8 (1.4") 28 Vpeak 35   Watt APL
12NW76/DE800 with passive filter (8 Ohm nominal) 85 Vpeak 150 Watt APL
Calculation for Vpeak = SQRT(R*P)
APL = P_AES/4
Impedance plot of all cabinets are planned in two weeks, so that would give any more info.
Has anyone more experience with the I-tech limiting? I've found some stuf about the I-tech HD but it's different from the older I-tech.
Motion54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Motion54 Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2018 at 12:31pm
Originally posted by smitske96 smitske96 wrote:
To be honest.. I haven't tried yet, but I can send you the email chain they send me (with the solution ofcourse).
Just informing us in the forum should be suffice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2018 at 10:40am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Motion54 Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2018 at 7:55am
So I've send an email to technical support from crown, and got a solution (hopefully).
Maybe that I have some time tomorrow to see if it works.
I'll keep you updated!Thumbs Up
Cool.
Any update?
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2018 at 10:26pm
DjLeco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DjLeco Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 10:08am
I-tech series are Class I (BCA, Ballanced Current Amp).
http://sound.whsites.net/articles/137234.pdf
Is one very good class amplifier but if precision adjustments of underlap/overlap settings bad adjustment occurs, it could fail easy.
I have repaired 2 pieces, is a good amp but it's limiter, personally I don't like, it allow for some small period of times HARD CLIPPING until it limits to a clean sinewave, ans as all "burst power amplifiers", cannot sustain declared output power for extended period of times, as "oldschool" amplifiers can do.
Some tests here.
Crown Macro-Tech5000i:
And here another model but the same in most part, Crown I-Tech 5000HD:
Edited by DjLeco - 27 May 2018 at 10:21am
I'm A Stupid SMART Romanian...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Motion54 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2018 at 7:29pm
I generally use my LMS to make any filter adjustments.
My Itech is used for kick duty only.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2018 at 7:24pm
Without the architect software, you almost can't do anything with the dsp..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Motion54 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2018 at 6:51pm
I have some I-tech 4000's laying around, and could't find the All-pass filters in the dsp..
Anyone had this problem before? Embarrassed
I couldn’t find them either in my 8000 the other day.
But to fair, the last time I accessed them was via a laptop and not via the front menu.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2018 at 1:32pm
Anyone? Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2018 at 7:27pm
U.Viktor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote U.Viktor Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2012 at 9:48am
We have had to repair booth I-techs, PowersoftK and PKNs previously. What was a surprise that Powersoft amps are really not so complex than I-tech. The amplifier part of Crown is at least twice as more complex than PowersoftK, probably this is the reason why the interleaved switching of the Crown sounds far better than simple Class-D Powersoft :-)
There are some parallel-connected small foil capacitors in the Crown , when one burns easily destroys the multilayer board and then pretty difficult to rescue the damaged board.
This page was generated in 0.061 seconds.
