  New Posts New Posts RSS Feed - Bertha BH-882 Build
Bertha BH-882 Build
 Post Reply Post Reply Page  123 10>
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Topic: Bertha BH-882 Build
    Posted: 08 January 2023 at 7:39pm
If huge SPL is not your main aim low tuned reflex would be my first choice. BMS18N862 is one option with its huge x-max.
Flat 25Hz Front loaded horns are going to be huge
Edited by csg - 08 January 2023 at 8:10pm
Zitikaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zitikaz Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2023 at 5:50pm
Originally posted by csg csg wrote:
Regardless of the change of scale, what exactly are you trying to achieve using 21” drivers in a box of this style?
HI
I would like to reach 25hz with good response natural bass, 21lw1400 seems suitable driver. Plan is to use Levan ext aswell
Maximum spl isnt primary goal, trying to get 25-60hz flat response.
or better look Rcf 18x401 and forget upscaling to 21"?
csg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote csg Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2023 at 11:46am
The function of a horn is to provide a better match between the driver and the air it is trying to move. In essence a horn increases the effective size of the drivers you are using. This makes the coupling between the box and the outside world more efficient.
Bigger drivers in a horn does not automatically mean lower frequency response or more output, although this may be possible with good design. But merely scaling up or down an existing design to suit your purposes does not automatically work, there are far too many variables for that.
BigSoundNorthWest View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigSoundNorthWest Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2023 at 11:27am
Originally posted by Twintub Twintub wrote:
21"/18" = 1.1667
Multiply all dimensions by 1.1667Smile
Nope.
bob4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bob4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2023 at 10:39am
21"/18" = 1.1667
 Very bad idea.
Jo bg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jo bg Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2023 at 9:52am
Scaling everything will make a dfferent horn and lower the tuning. If you want to keep same tuning you have to keep same horn length and just find a way tofit bigger driver - check rear chamber too.
27 is already a low tuning, lowering it will probably lower efficency in exchange for not so useful 23hz output - unless you are going for cinema fx
Twintub View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Twintub Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2023 at 12:14am
21"/18" = 1.1667
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zitikaz Quote  Post ReplyReply Direct Link To This Post Posted: 07 January 2023 at 11:29am
Can someone help me to scale up drawings so i can use 21" driver?
APC321 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote APC321 Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2022 at 7:51pm
VECTORDJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VECTORDJ Quote  Post ReplyReply Direct Link To This Post Posted: 29 December 2022 at 11:43am
Bertha Hints - Make sure all internal Joints are Air tight.....I coated all Joints with Epoxy after building the Horn....A small Air leak will reduce Bass Output.....Make sure to get rear door very tight....The Klipsch Audio Papers has a Paper were Klipsch writes about Air Leaks....I found I like the Sound of two 1/2 Berthas better than one dual 18 Bertha......1/2 Berthas are also a lot less work moving.....VECTORSONICS
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zitikaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2022 at 10:21am
Originally posted by Lee In Montreal Lee In Montreal wrote:
Originally posted by nomercy82 nomercy82 wrote:
Post pictures when you're done. I'm curious about your design. How does a 1 foot extension of horn length make up for a 3 foot hyperbolic extension?
Like that. With a 36" deep extension, it makes it "theorically" a 21Hz horn once the back chamber and throat size are tuned for a JBL 2242. Without the extension, it is a 27Hz horn for a 1/4 wave. Theorically. ;-)
How was the real results?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zitikaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2022 at 10:20am
Hei
HELP NEEDED!
Can someone help me to scale it up a bit, to fit 21LW1400 and simulate it in hornresp?
Plan is to build these monsters with 21" drivers :)
