1850s void loaded |
Amplighting&sound ![]() Registered User ![]() ![]() Joined: 31 July 2011 Location: Essex Status: Offline Points: 359 |
![]() ![]() ![]() ![]() ![]() Posted: 06 November 2012 at 12:05pm |
Yes please fill free to add to this any 1
Requiem ![]() Old Croc ![]() ![]() Joined: 20 January 2011 Location: Bristol Status: Offline Points: 1787 |
Any other opinions on this? i would like to hear what other people think. Personally i run it 24db linkwitz-riley 40 hz-115 hz, with a bit more eq on the sub bass
www.requiem-soundsystem.com
Custom Martin Audio WSX, USB & CSG Soundsystem based in Bristol |
Thank u m8 will give it a try
teknojay ![]() Registered User ![]() ![]() Joined: 08 November 2006 Location: Peterborough Status: Offline Points: 415 |
Heres how i run mine
2 x Void Infinite8 24db butterworth 43hz - 110hz(cross them over a bit lower if your tops can drop lower, best to have the 1850's doing as little as possible) I like to add about 3db around 90hz to really bring out the kickdrums |
Hello there i hav 8 1850s loaded with v18 1000 can any 1 tell me the best way to run them as in xover /amps and eq
