Windows 7 x64 - Fresh Install, Slow Updates |
Muckerbarnes1 ![]() Old Croc ![]() Joined: 20 March 2010 Location: Stroud Status: Offline Points: 2654 |
![]() ![]() ![]() ![]() ![]() Posted: 27 November 2012 at 9:20am |
Usually DHCP settings and crap firmware. A commom prob with routers, then dropping packets.
I've had a few with issues. At home a crap router supplied by AOL has been switched on for at least 3 years. Not one issue.
Billy Dawg.
Tony Wilkes ![]() Old Croc ![]() ![]() Joined: 02 August 2004 Location: West Midlands Status: Offline Points: 4840 |
Had these problems till I changed my router, had to re-set on average once every 2-3 days. Since changing router not a single problem in 9 months.
The new router is a TP-Link and is so much better than the D-Link it replaced. Tony
Steve_B ![]() Old Croc ![]() Joined: 29 September 2007 Status: Offline Points: 1587 |
In a similar vein, every so often the Mrs complains of no
internet connection. Her computer (well it is my laptop that she has commandeered so it could be just karma) is seeing the rest of the network so that bit is
working and internet connection is always fine on my PC and my phone’s wi-fi access
sees it too. As with your problem a router reboot fixes it. |
levyte357- ![]() Old Croc ![]() ![]() Joined: 27 July 2012 Location: UK, South East Status: Offline Points: 8004 |
Solved it...
Router reboot.. Strange, on main pc everything 'nettish is fine... ![]() |
Just completing fresh install of 7 x64.
Install fairly quick, windows updates slow, often failing. Have tried install on SSD & Various HDs, same result. Wasn't like this last year... Is it due to all the new '8 fanboys updating ? |
