  New Posts New Posts RSS Feed - 186 braces
186 braces
b grade View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote b grade Quote  Post ReplyReply Direct Link To This Post Topic: 186 braces
    Posted: 17 December 2012 at 4:50pm
I assume you mean the dual braces in the mouth.  I spaced mine so that they would be evenly spaced, and the internals all being 600 mm,  I centered them at 200 mm apart and 200 from each side.  So measuring from one side it would be 191 mm to 209 mm for the first brace and 391 mm to 409 mm for the second brace, taking into account that the wood is 18mm thick.
superspunk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote superspunk Quote  Post ReplyReply Direct Link To This Post Posted: 17 December 2012 at 11:54am
Which is the distance between braces?
