Boominator MINI (development thread) |
Page 123 102> |
Saturnus ![]() Old Croc ![]() Joined: 13 July 2010 Location: Copenhagen Status: Offline Points: 2020 |
![]() ![]() ![]() ![]() ![]() Posted: 19 December 2012 at 8:18pm |
Please note. This is a development thread that is expected to be complete in Autumn 2018. Please read all responses to make sure you have noted all changes to the design before beginning construction. Please note: the Aura NS6 this build was originally based on have sold out and will not be produced anymore. A new design based on Dayton Audio drivers and advanced DSP amplifiers is in the process of being completed during Autumn 2018.
Edited by Saturnus - 07 August 2018 at 1:51pm |
bitSmasher ![]() Old Croc ![]() ![]() Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2289 |
*You will now be notified by email of all Replies in this Topic.
interested in the boomeganator ![]() |
lost eden ![]() Young Croc ![]() Joined: 04 April 2011 Location: Dundee Status: Offline Points: 942 |
Interested. Still got a box of parts under my bed (incluidng a 10" Fane & Face CD) from a boombox project I was planning because I couldn't justify a full boominator, but never actually built anything because I knew it would pail in comparison to a boominator... This could be the answer ;D
roubi ![]() Registered User ![]() Joined: 14 June 2012 Status: Offline Points: 39 |
Maybe I'm gonna say something stupid but why not keeping the Amp6 in replacement of the Amp32. It is easier to solder !
Zuk4wd ![]() Registered User ![]() ![]() Joined: 30 November 2012 Location: The Netherlands Status: Offline Points: 12 |
good idea's ,
i would love somthing light with maybe 2 of these drivers:
http://www.eminence.com/speakers/speaker-detail/?model=LA8_CNMBA - http://www.eminence.com/speakers/speaker-detail/?model=LA8_CNMBA
why is the back to back design ? 360 degree sound seems not something that i would want.
I don't want to start with Adam and Eve of simple acoustics again. It's primarily an efficiency issue. In a bipolar design the bass output from the speaker on the "back" augments the output from the "front" with 6dB under the summing frequency. In the Boominator it's at 384Hz. In principle you could just let the drivers on the "back" play bass, and nothing else. But so much would be lost. You cannot really comprehend why a bipolar design with 360 sound is so vastly preferable for this type of speaker until you hear it. No one who has ever heard it has said: "Great, but could I just get the sound only from the front instead". No, they all say: "Great, can I get the same sound at home if I use bipolar speakers there as well?" Edited by Saturnus - 20 December 2012 at 7:10pm |
Certainly also an option. And it would fit, so no problems there. |
@ Saturnus :
thanx for explaining !
alphabetikal ![]() Registered User ![]() ![]() Joined: 20 May 2010 Location: UK Status: Offline Points: 217 |
maybe instead of batteries, use super-capacitors ?! ;-)
Firemedic023 ![]() New Member ![]() Joined: 21 December 2012 Location: United States Status: Offline Points: 1 |
I already built an 8" version of the boominator and now have almost all of the parts on order for an original version which should be complete by February. Now I am already imaginating the glory of the Mega Boominator! It will be perfect for us since we only need about 8 hours of run time for our football and country concert tailgating events. I can't wait to see the plans!
tcourtneyvincent ![]() Young Croc ![]() Joined: 04 January 2011 Location: Devon Status: Offline Points: 1146 |
so when is this going to be released?
I apologize for the delay. The first two tries had to be scrapped. The originally planned one simulated fine but wasn't DIY friendly enough in that it relied on some very fancy routing. The second try where the center brace was scrapped didn't simulate to well as there'd be too much vibration in the cabinet (power lost and different effective tuning due to lower Ql value). I think I have solved most problems now, and will simulate it. It'll be slightly larger at 200x200x700mm (length is reduced though) but will be much easier to build and have a central compartment for electronics just as the original Boominator. And that'll be the same 66mm width as well so a 12v 7ah standard SLA can be used instead of it having to be a li-ion battery. This also means you can use any amp you like as getting sufficient cooling is no longer an issue either. I should have it ready shortly (though not today). |
Page 123 102> |
