  New Posts New Posts RSS Feed - Replacing ribbon cable on Behringer DEQ2496
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Topic: Replacing ribbon cable on Behringer DEQ2496
    Posted: 01 August 2022 at 10:05am
The most secure would be to solder. I think that is the recommended route for this repair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2022 at 8:44am
I can't advise on shipping. Have you tried Mouser or Digikey?
North Staffordshire
AudioLab00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AudioLab00 Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2022 at 10:04pm
Originally posted by kedwardsleisure kedwardsleisure wrote:
Quote I found some of them on eBay and aliexpress
You need to buy a good quality one.
Thanks for your reply.
I’m asking about type of cable and connectors before to think in which brand and quality.
I wrote about ebay and Aliexpress just because they are first coming in google search.
Maybe my request was not right.
I could check in electronic providers here.
Before to buy something I need to know 2 things.
The cable is a simple Ide cable with 26 pins (13x2)?
It has one ide female connector in the processor side and the other one is called Idc transition. Right??
My doubts are about the Idc. Checking in different store I didn’t find one that looks similar.
Must to be, I suppose, with male 26 pins to solder them on the I/O board. I only found idc open  upside and with female socket downside.
For this reason I wrote today in this thread.
I need help to find best reference to the parts required.
I live in Canary Islands. Here is not so simple to buy parts and also is not too simple to buy them on internet. A lot of sellers prefer to ship not to Canary Islands.
So, again thanks for your reply, but if you can I need to know something more. Maybe if possible to have some links.
Thanks again man.
Edited by AudioLab00 - 31 July 2022 at 10:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2022 at 7:13pm
The engineering that goes into a reliable IDC connector is quite advanced and needs tight tolerances and years of experience making them out of the correct materials and to the right specification. These fail because they're cheap.
A branded genuine one is the way to go from a reputable japanese or western company.
North Staffordshire
Post Options Post Options   Thanks (0) Thanks(0)   Quote AudioLab00 Quote  Post ReplyReply Direct Link To This Post Posted: 31 July 2022 at 6:54pm
Hello. I know is an old thread but just today I had the same issue.
Could someone give me some links to buy parts?
I need a 26 pin ide cable and have to peal one side?
Where I could buy 26 pin transition connector?
I found some of them on eBay and aliexpress but I’m not sure if they are  the connector needed.
Thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 29 March 2013 at 3:48pm
The correct way is to unsolder the transition connector from the back pcb. Buy a new quality branded one, eg Fujitsu, 3M, Amp, crimp it on new ribbon, solder it back in. If you want to solder the cable to the idc forks of the old connector, that's great but sounds like a fiddle to me! If you arent confident to unsolder the old one, maybe this is a safer DIY solution.
Edited by kedwardsleisure - 29 March 2013 at 3:48pm
North Staffordshire
stevie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevie Quote  Post ReplyReply Direct Link To This Post Posted: 29 March 2013 at 1:11pm
Thanks. I'll give it a go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 29 March 2013 at 12:39pm
To the pins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevie Quote  Post ReplyReply Direct Link To This Post Posted: 29 March 2013 at 12:25pm
Did you solder to the pins on the transition header, or underneath the board, Marjan? Now were did I put that magnifying glass......?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 29 March 2013 at 12:21pm
Just solder it. It is how i get rid of the frying egg sound out of the dcx 7 years ago. Doing great since then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevie Quote  Post ReplyReply Direct Link To This Post Posted: 29 March 2013 at 10:45am
Could anyone supply some (idiot-proof) instructions on how to 1. replace the transition connector or 2. re-use the transition connector, and connect a new ribbon cable?
Centauri View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Centauri Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2013 at 10:02am
you'll have to replace the entire transition connector..they aren't meant to be re-used.
But with care they CAN be reused (have done it heaps of times with Behringer gear), and is preferable to the real possibility of damaging the fragile Behringer circuit board.....
