  New Posts New Posts RSS Feed - 186 or USB or ... ?
186 or USB or ... ?
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Topic: 186 or USB or ... ?
    Posted: 09 January 2014 at 11:25pm
Originally posted by Mark James Mark James wrote:
seriously hb1505c1 in this case 80hz upwards absolute winner got a pair of double vrsions ourselves :P epic :-]
of course if you have the space, long straight horns are epic ! :D
do you have some pics mark?
Edited by corell - 09 January 2014 at 11:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2014 at 11:18pm
Originally posted by T-Bone T-Bone wrote:
Hi corell any new development on this build was thinking about the F215 the other day and saw this on speakerplans. Can I use a Faital Pro neo 15" on this design if you have the sims for it?Thanks!
have you forgotten about that one ? ;) :
http://forum.speakerplans.com/another-15-bph_topic82127_page1.html
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2014 at 10:34pm
me so horny me love you long throw
horn loaded for her pleasure
T-Bone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote T-Bone Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2014 at 4:33pm
BASS, how low can you go!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2013 at 8:55am
Ahh I missed the h have you looked into the sellenium hb 1505c1?
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2013 at 2:14am
Drivers with a little lower BL factor seem to be smoother:
Uploaded with ImageShack.com
alanstar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alanstar Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2013 at 2:08am
Labs 30-80 res 3 low from there id check settings
Hi Mark, I'm planning on using the R3SH because I think I would rather have a separate 2x 15" horn than the 1x 18" horn in the R3.
A block of 8 labs sounds best cut at around 60hz imo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2013 at 1:24am
2 pi simulation is not that impressive, will try to improve it tomorrow.
And i am going to sim some other drivers in that.
The bracing in the backchamber is not necessary, i added it to decrease displacement, i would juse it for the door.
Edited by corell - 18 September 2013 at 1:30am
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2013 at 8:19pm
Originally posted by corell corell wrote:
I tried a 15" BPH, 60 x 57 x 60 cm (i think labs are 57 cm wide?) with PD 158. Would be a really easy build, 106 db/w/m,  -3db points are 70 and 200 Hz when you use 4 of them. I will post plan and sim when i know how to do it.
Would be very impressive to see a new bph design, with those specs, made up in only 2,5 hours.
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2013 at 8:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2013 at 7:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2013 at 6:42pm
That was my thought aswell. I dont like the idea to use 18" for that range, if you are not after a one-bass solution and need it to go as low as possible (USB). Tell my a size and a budget (i guess its not that tight, as your after some f1 tops^^) and i´ll sim a 15" bph against a 12" or 2x12" bph.
