  New Posts New Posts RSS Feed - Newbie building 186 Horns *** Finished *** :-)
 Post Reply Post Reply Page  123 6>
 Rating: Topic Rating: 1 Votes, Average 5.00  Topic Search Topic Search  Topic Options Topic Options
Fabianm_be View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fabianm_be Quote  Post ReplyReply Direct Link To This Post Topic: Newbie building 186 Horns *** Finished *** :-)
    Posted: 17 July 2014 at 9:31am
Hello izzzzzz6,
all your concerns are logical but I buit the top already a few months ago and we are very happy of the result: http://forum.speakerplans.com/smt-212-building_topic86007.html
izzzzzz6 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote izzzzzz6 Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2014 at 7:34am
How is the building of the tops going? I would imagine that the midrange from those horns would be very powerful but you may find that they lack a little brightness with out boosting the gain around 17-20k, i would recommended several smaller compression drivers 1" or 1.5" rather than a single 2" or a combination of both so you have more control. many 1" compression drivers can really change the sound if setup correctly. A favourite layout of mine on smaller speakers is a mini array of tweeters usually 2 in series and two in parallel, 16 total if you like for more control and power but it starts to get expensive and difficult to build. With larger applications i'm thinking 4x 1" compression drivers would make a nice job. 2 sets in parallel and those two sets in series to retain the original impedance but increase power handling. The other advantage with using 4 1" compression drivers in one cab is that the horns can be splayed out at different angles to get a greater coverage in the room. (which is kind of necessary to avoid interference patterns, this also depends on the shape of the horns used).
Sound
ClubJDj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ClubJDj Quote  Post ReplyReply Direct Link To This Post Posted: 24 June 2014 at 4:15pm
Hello!
Is it possible to get your Sketchup Drawings?
kind Regards!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fabianm_be Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2014 at 7:54am
Originally posted by Gfoster Gfoster wrote:
I am looking to build the SMT 212's however in a single driver version, so looking forward to seeing your pictures, what drivers etc have you got?
The wood working will start Today and I will create a post for that.
I will use:
- 2 Compression P Audio BM-D750 Serie 2 http://www.p-audio.co.uk/pdf/BM-D750.pdf
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fabianm_be Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2014 at 7:52am
that truss build really scares me...
whats stopping it falling backwards/forwards [and holding the pieces together!]... hopefully not just those cableties/straps onto the railingsOuch. Like the creativity [layout], HATE the rigging. So damn unsafe, not to mention careless.
If you want to do this kind of thing, get some swivel clamps at least, so the thing can be clamped together properly - and actually resemble something load bearing. They are cheap and common - used by scaffolders, absolutely no excuse here. Leave the cable ties for.... *cable tieing* and use clamps for *clamping*! Also build a proper base for the thing [using truss baseplates] so it cannot tip forwards or backwards.
try getting the midtops up higher next time too....
sorry to be harsh, i can see you put a lot of effort in, the lighting and set looks awesome, but the little things cannot be ignored!
I 100% agree with you, they did too many wrong stuffs with the trussing. I will request they buy clamps like you suggested.
burningbush View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote burningbush Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2014 at 7:21pm
I wore one of those once, very uncomfortable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2014 at 7:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2014 at 7:11pm
Gfoster View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gfoster Quote  Post ReplyReply Direct Link To This Post Posted: 25 March 2014 at 6:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fabianm_be Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2014 at 10:51am
And finally, some pictures of the light just before the opening of the first gig.
I think these young guys made a good job transforming this small venue in a single dance floor just for 2 nights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fabianm_be Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2014 at 10:46am
Hello All,
I will start to work on the tops next week.
Waiting for this, here is a few pictures of the last use of the 186 this week-end.
My son is working with another guy to create 2 events based on young talents. Everyone in these organisations (including the 8 DJs) are from 16 to 19 Years old.
I just gave a hand half a day for the setup.
The Amp Rack with a borrowed additional amp and a processor:
Backstage:
186 Horns on side of a dual 18 sub using the same RCF drivers. So, with the processor, we worked 3 ways: Sub, horn, full range speakers. Crossover points was 80 and 150.
DJ corner. The mixer we used (DJM 600) was not yet installed.
Will include some pictures I took just before the opening in the next post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fabianm_be Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2014 at 10:31am
lil comment here, stack the 186's sideways one on top - get the SMT212 up to height!
Going to be a potent rig once complete! Time to get a proper bass amplifier and speaker processor also....
You are right, this is better like this Smile
This page was generated in 0.074 seconds.
