Martin magnum 2000 smoke machine |
Richthelightningguy
Joined: 27 January 2012 Location: Lincoln Status: Offline Points: 51 |
Topic: Martin magnum 2000 smoke machinePosted: 01 February 2014 at 3:18pm |
Hi Problem with my mag 2000 at last gig has anybody come across this kind of problem before
turned it on waited for it to warm up .. about 10 mins came back to it its stone cold look on rear make sure its turned on etc power is on Led on removable control panel is on but power Led on unit is flashing,Red heat Led is not on ( green ready only comes on when ok to go ) took the covers off to press reset on thermal trip also checked fuse all ok ( although i think thermal switch needs a look at too make sure ) turned off turned on and it started to work Two steady Red Led on back power and heat let it warm up ok tested output all ok . relocated machine then it would not work again same fault took it home set it up this morning its working straight out of the box (bouncing around in van prob ) so im thinking a dry solder joint or bad connection somwhere has anybody else had this happen .....?? when its working it great peice of kit Thanks Rich |
WITHOUT LIGHTS ITS JUST RADIO
GAZ.
Joined: 16 January 2007 Location: Hertfordshire Status: Offline Points: 2428 |
Posted: 01 February 2014 at 11:33pm |
If I remember rightly there is 2 triacs on the PCB inside, one controls the heater, the other the pump. Would be worth checking those for dry joints. Whatever you do dont touch the heatsink, its live when the machine is powered up!
I used to have one of these machines, may have some parts left somewhere. |
100% Earth Moving Bass
Richthelightningguy
Posted: 02 February 2014 at 1:06pm |
Ok thanks will have a look
