  New Posts New Posts RSS Feed - PD.186 / 186.2
PD.186 / 186.2
 Post Reply Post Reply Page  123 7>
GwanStefani View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GwanStefani Quote  Post ReplyReply Direct Link To This Post Topic: PD.186 / 186.2
    Posted: 30 April 2015 at 10:15am
Yeah, wish I'd known about the sticker before though, had to buy a multimeter to test the ohms. Cheers Paul
PauliePaul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PauliePaul Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2015 at 12:05am
Yes, that's a PD.186 and not a PD.186/2.
Just a side note, it's a 4ohm driver too, in case you didn't already know. See "PD.186.4" on sticker under terminals.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GwanStefani Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2015 at 11:58pm
So, took the drivers out and they seem to be the older model, just thought I would post a couple of pictures up here and see if people are agreeing. We're trying to sell these on so I want to make sure I'm not lying to anyone
Post Options Post Options   Thanks (0) Thanks(0)   Quote GwanStefani Quote  Post ReplyReply Direct Link To This Post Posted: 29 April 2015 at 11:31am
Thanks Paul, will need to take them out and measure up but I think our's may actually be the older model
Post Options Post Options   Thanks (0) Thanks(0)   Quote PauliePaul Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2015 at 10:44pm
PD.186/2's have a rounded chassis flange and smoother lines, also the bottom plate on the motor has a chamfered edge. The badge will on the back will still say PD.186, but the sticker on the motor under the terminals will say PD.186/2. Also, any driver with a production date after say May 2013 will be a /2 model.
And finally, the PD.186/2 are 6mm deeper than the PD.186.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GwanStefani Quote  Post ReplyReply Direct Link To This Post Posted: 28 April 2015 at 10:31pm
Does anyone know if there is a definitive way to tell between the original 186 and the 186/2 just by looking ?
Adam_Iron_Horse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam_Iron_Horse Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2014 at 6:22pm
My pd 186/2 have both bolt patterns I believe...
Kryptonik Sound Kollective
www.facebook.com/kryptoniksoundkollective
BASSHORSE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BASSHORSE Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2014 at 6:07pm
good ive got 4 waitin for the price booom LOL
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2014 at 5:48pm
he's saying the 8 hidden holes are no longer there.
Which is is fantastic again, if you have 186 Horn, or other folded horn, tnutted for interior PD holes, and cab is almost impossible to re-tnut.
So I guess old version PD186 will also be going up in price, as well as old version PD1850.
hmaudio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2014 at 3:31pm
ahh i get you sorry i miss read.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2014 at 3:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote hmaudio Quote  Post ReplyReply Direct Link To This Post Posted: 08 June 2014 at 2:15pm
recently built some cabs using a mk1 chassis for bolt pattern then fitted mk2 chassis and had no problems
This page was generated in 0.064 seconds.
