Forum Home Forum Home > Plans > Punisher and X-tro
  New Posts New Posts RSS Feed - xtro capabilities
xtro capabilities
mpvw72 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mpvw72 Quote  Post ReplyReply Direct Link To This Post Topic: xtro capabilities
    Posted: 18 August 2018 at 3:11pm
at present I'm using 6 XTs for the 15" I have the DAS B-30. The 8" Celestion TF0818MR. Hi end Peavey RX22 and it took me a while to get the settings right so I'll put my settings which may not be what anyone else wants but it's a start. My bass is really big and loud and my mid got lost but after many tries I'm almost there. The Hart of the top is the 8 get that right and you can't go wrong my setting from a DBX management
Hi 1.7KH slope BW24 to open
8s 972HZ slope LR12 to 2.0KHz slope LR24
15s 129HZ slope BW18 to 749Hz slope BW12
Now it comes down to the amount of power assigned to each via the power amp
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2016 at 2:50pm
I think the recommended driver is 18sound and I'm not sure it's a cheaper solution
krestudon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote krestudon Quote  Post ReplyReply Direct Link To This Post Posted: 29 August 2016 at 9:11pm
Never heard the H3's, as they're not so popular here in spain, but built Xtros using Beyma 15p80nd, which can hold a bit more power than the recommended B&C's, and the kick is awesome.
Maybe the upper part is running out of steam before the lows in my build...
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 25 August 2016 at 5:46pm
I think I'd prefer my xtros with xt8s over a h3 top
That's actually what I'm using over discosucks cyclops now :-)
I think the kick is superior in that staight horn, no honkiness, the xt8 with the b&c sure is insane too:-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote mpvw72 Quote  Post ReplyReply Direct Link To This Post Posted: 25 August 2016 at 1:52am
i have been using xtros for a while now and i find that they cover the distance and fit in the space i need to fit the best of the mids ive used, but with most boxes its all about the settins used to get out the best of the box and you can go online and find some recomendations for most if not all the big name boxes but not the xtro.
Do you have a recommended setting crossover, EQ, anything along those lines.
I like the 2 8"s first time im seeing it but ill give it a try
AM55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AM55 Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2013 at 1:16pm
The reason you use a 2" HF driver is if you need a lower crossover point, the 8" stretches up high enough that you don't need a 2" you can use a 1" that will be cheaper, smaller and have better VHF response.
nativelayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nativelayer Quote  Post ReplyReply Direct Link To This Post Posted: 08 November 2013 at 1:05pm
Would a 2" Compression Driver work well in beefing up the top end, or does the increased size affect the double 15" horn too much?
There is no authority but yourself.
godge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote godge Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2013 at 4:13am
I agree with toasty that the xtro had a boxy sound to it from the kicks. The 8" part wasn't the problem though with the fibre glass horn. It was more lacking in top end from the 1" I always found and could of done with something more powerful. I had the 1" running of a xt800
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 24 October 2013 at 4:21am
Forget the wooden horn. Mykeys horn is the one you want to use in the xtro.
All of the ones I've used and listened to have these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2013 at 11:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2013 at 10:12pm
It all depend what your need is. Xtros are designed to complement the punishers. So they dont go low. Hence their not so warm tone.
I have nothing against the H3. But if you need more kick, then xtro is a better box.
The mid and high of both boxes are very similar, so b&c loaded xtro should sound very comparable in 300Hz and up part of the sound with the H3.
Maybe it should, but it doesn't, sadly.
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 23 October 2013 at 10:01pm
we made several versions of the Xtro with different drivers and midrange solutions
the best results we had were with using a dual 8" midhorn and a 2" exit horn coupled to 4x 1" drivers firing into a manifold.
It looked like this:
The midrange horn in the original xtro is not very good.  But keep in mind that it was a design mainly aimed at the techno scene.
Ex Nexus_3
