  New Posts New Posts RSS Feed - EA Hybrid Folded Horn
jayam000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jayam000 Quote  Post ReplyReply Direct Link To This Post Topic: EA Hybrid Folded Horn
    Posted: 19 April 2017 at 3:13am
Originally posted by E.A E.A wrote:
I've planned to post the plans but after several tests I recognised problems with excursion so if you have some time I'll finish the mk2 plans and post it (btw exc. problems occurred above 135dB).
Cheers.
Have you finished markII plans?
"I do not want to make my stomach a graveyard of dead animals." George Bernard Shaw
Darkstar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darkstar Quote  Post ReplyReply Direct Link To This Post Posted: 11 October 2014 at 4:54am
Allrite mate. First of all thanks for the reply, really much appreciated.
Secondly yes, I've got the time for this no problem. I've got some double 18's refurbished ported horns (which also had some excursion issues) and I'm planning on making some 15's to put onto them and step up the bass output range, but until I'm finished with the 18's I'm not going to have the quids to build up anything else.
This design would fit perfectly though, hit me up when you got anything new.
Cheers Big smile
Edited by Darkstar - 11 October 2014 at 4:55am
E.A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E.A Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2014 at 11:49pm
Cheers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darkstar Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2014 at 9:35am
Does anyone have a plan/paperwork for these?
Or just generally for a ported horn 15" enclosure?
I'd love to have one of these. Congratulations and thanks in advance for anyone who can provide me some measures. Clap
Edited by Darkstar - 10 October 2014 at 9:39am
E.A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E.A Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2014 at 11:39am
I love it Smile... warm as hell, without any colorization especially below 80-100Hz.
Teunos, now I'm trying to improve the lower cut-off with a weird design. I don't know how to describe it... like a horn loaded BP12. It seems to work on paper but group delay is a problem.
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2014 at 10:26am
nice one EA, bet you're loving it!
crossed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote crossed Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2014 at 9:37am
Good job, i like the build quality.Thumbs Up
Teunos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teunos Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2014 at 7:05am
Yes, which is why they are ported horns. It is basically a hornloaded BP6. i builttwo myself and was quite impressed with the results. It's just that i found it rather hard to get any design to play lower than 40Hz, both in simulations as well as in real life. Your cabs follow about the same response as mine did so i think these cabs can sound great as well!
Best regards,
Teun.
all bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote all bass Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2014 at 6:49am
Are those ports at the top of the hornmouth?
E.A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E.A Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2014 at 12:37am
Sure it's huge, but the only size limit was the car and it fits. Big smile
Thanks! Smile
E.A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E.A Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2014 at 12:25am
There is a trap cut-out on the other side. Smile
corell View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corell Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2014 at 12:20am
does this mean you cant access/change drivers then?
nearly 500l is not what i would consider small LOL but well, if you are happy with it ;)
looks like a good job you did there!
Edited by corell - 26 March 2014 at 12:25am
