  New Posts New Posts RSS Feed - 12 HDs - what would they drop to?
Keen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keen Quote  Post ReplyReply Direct Link To This Post Topic: 12 HDs - what would they drop to?
    Posted: 27 March 2014 at 12:51pm
Originally posted by Wrek0ne Wrek0ne wrote:
Originally posted by Edd Jordan Edd Jordan wrote:
why not build 8x 18" reflex bins easy build and portable will drop low etc.
Hitting.... Nail.... Head!
HD15's just don't play low... even in massive groups.
My advice is buy high end B&C / 18sound / FaitalPro / RCF drivers and stick them in 160/170L reflex bins!!!
aren't you doing horns anymore Wrek?
LjudLahger View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LjudLahger Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2014 at 9:15pm
This looks good on paper, would love to try it, RCF LF18X401 in a reflex
Wrek0ne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wrek0ne Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2014 at 8:34pm
Poll this!
Edd Jordan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Edd Jordan Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2014 at 4:56pm
Teknotice View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teknotice Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2014 at 3:56pm
Downsizing the rig, we had 8 1850s they are gone now. HD15s more portable etc. etc.
'why on earth do you need this much amplification?!'
levyte357- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote levyte357- Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2014 at 11:23am
Why not just build 8x Hornloaded subs ?
Surely easier to transport, cheaper on drivers, amp power, less reliance on building power ?
I've heard stacks of 6x HD15s used as subs, and also 6x 1850 Horns in a stack, and neither did much below 50hz in my books.
Have heard 2x stacks of 4x 186 horns, loaded with various drivers, IMHO sounded much warmer, deeper.
Edited by levyte357- - 26 March 2014 at 11:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Teknotice Quote  Post ReplyReply Direct Link To This Post Posted: 26 March 2014 at 11:16am
Hi SP
If you had a wall of 12 HDs all loaded with PD154s - powered by budget amps
stacked in couples, bracing to bracing., rows of four.
What frequency could/would you push them down too?
Also, I know they are supposed to be mid bass boxes but with the above set up, could they handle a bit of jungle/dnb bass?
Cheers!
