  New Posts New Posts RSS Feed - why did my solder iron stop working?
discosucks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote discosucks Quote  Post ReplyReply Direct Link To This Post Topic: why did my solder iron stop working?
    Posted: 08 April 2014 at 8:41pm
Got this new gas solder iron made by ferm ,
Now it was filled when i got it but last week it ran out ,
I bought gas , the gas came with little heads , one of witch kinda fits but its hard to know
if its the right fit .
Now iv tried filling it , cant really tell if its going in but it doesnt seem to be as nothing is coming out the top when turned on .
Would it be because im using cheaper gas? It says on the ebay add where i bought it that it will work on any lighter gas .
heres the bottom , iv tried opening what looks like the valve , still no good .
Post Options Post Options   Thanks (0) Thanks(0)   Quote mk2_ginger_biscuit69 Quote  Post ReplyReply Direct Link To This Post Posted: 08 April 2014 at 8:47pm
when it does fill you will hear a whooshing type noise as it fills [gas transfer], sounds like the fill kit isn't connecting too the thing. I have found this with many lighter refill kits, trying to refill lights.... only 1/10 actually workOuch.
looks like a nice piece of kit, very handy to throw in the toolbox!
Post Options Post Options   Thanks (0) Thanks(0)   Quote discosucks Quote  Post ReplyReply Direct Link To This Post Posted: 08 April 2014 at 8:58pm
It fills my lighters no problem! iv tried 3 different gas cans now and none have worked .
A nice lady from a local shop has ordered me a clipper gas can , im thinking maybe the cheap gas is the problem .
Yea its really nice , its super hot too .
Also one of the tips is made for shirking shirk rap
kanks View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kanks Quote  Post ReplyReply Direct Link To This Post Posted: 08 April 2014 at 10:12pm
I had this with mine just try different ends and also without one also try holding it open as you do it but be careful not to hit the igniter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 08 April 2014 at 11:17pm
mine's the same, it won't fill with any of the supplied ends. Just push the bare nozzle square against the fill valve on the iron.
Don't think the gas will be faulty, butane is butane. I have used every type and they all work...clipper, swan, ronson, london, etc
North Staffordshire
Pinyorouk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pinyorouk Quote  Post ReplyReply Direct Link To This Post Posted: 08 April 2014 at 11:31pm
Also make sure that gas can and soldering iron are upside down when filling. Silly comment ... but you never know Smile
dlyxover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dlyxover Quote  Post ReplyReply Direct Link To This Post Posted: 08 April 2014 at 11:51pm
Same here with my gas jobbie.
Bare nozzle into your iron, you should hear the hissing as the gas transfers as ginge mentioned.
no noise its not filling, gas spraying everywhere (lol) no filling.
cravings View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 08 April 2014 at 11:52pm
i had a gas iron that failed once... i mailed the manufacturer and i got a reply telling me that they only rated certain brands of butane.. so eh.. according to him. butane is not just butane.
not the same brand as discosucks' one there. i'll try and find the mail..
Post Options Post Options   Thanks (0) Thanks(0)   Quote cravings Quote  Post ReplyReply Direct Link To This Post Posted: 08 April 2014 at 11:56pm
Originally posted by Mr Soldering Iron Mr Soldering Iron wrote:
Without seeing you iron I would be reasonably certain that what you are experiencing is a partially blocked jet. This is caused by poor quality gas. I know you mention that you buy lighter gas from your local hardware. But brand of butane gas is it?
Poor quality butane gas is nearly always the cheapest also. The reason being that there is a much higher propane % in the cheaper gas to keep the cost down. Propane has significantly high levels of oils and impurities that butane and these will block the jet in you pro piezo. Sometimes you can get lucky and it may take a while for the jet to block and other times it can happen the first or second time you use this gas. The end result is usually the same. That is why we recommend that a consumer uses a good quality gas such as Ronson or London gas etc. They are only slightly dearer but the quality is significantly higher.
madboffin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 09 April 2014 at 12:02am
There's normally a little window somewhere so you can see if it's full.
As has been said, the can should be inverted (nozzle down) when filling. You may need to press quite hard to open the valve.
The brand name on the gas refill shouldn't matter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote discosucks Quote  Post ReplyReply Direct Link To This Post Posted: 09 April 2014 at 12:08am
does it no spill out all over when you do it like that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote discosucks Quote  Post ReplyReply Direct Link To This Post Posted: 09 April 2014 at 12:17am
Maybe the output on mine is blocked then , as I think gas has gone in at some stage . cant see how that would have happened though , guess I will have to dismantle it haha .
