winisd |
warrenstephenson ![]() Registered User ![]() ![]() Joined: 09 April 2012 Location: bedford Status: Offline Points: 85 |
![]() ![]() ![]() ![]() ![]() Posted: 09 May 2014 at 10:16pm |
Can anyone send me or tell me were i can locate a version of winisd that i can use the box shape part in as the version on the web site does not allow this function to work
thanks warren |
DMorison ![]() Old Croc ![]() Joined: 14 March 2007 Location: Aberdeen Status: Offline Points: 1604 |
I don't think any version ever had it working - I used 0.5 for a long time and it wasn't enabled in that, and 0.7 doesn't even make mention of it anywhere I can see.
To be honest, it's not that hard to work out box dimensions once you've got your design, so I can see why they dropped it. HTH, David.
lgosdset ![]() Young Croc ![]() Joined: 28 September 2010 Location: Reading ish Status: Offline Points: 1203 |
? you just put in the two dimensions you want, select your sheet thickness then double click the empty box and it gives you your third dimension.
all bass ![]() Old Croc ![]() ![]() Joined: 11 October 2012 Location: the Netherlands Status: Offline Points: 1855 |
Bassbox Pro will do dimensions. If I remember correctly it can even do some none square box calculations.
But as others have said before... It's not that hard with a little drawing and a calculator. |
bitSmasher ![]() Old Croc ![]() ![]() Joined: 23 June 2012 Location: Melbourne Status: Offline Points: 2289 |
It's easy enough to work backwards if you know your target volume. Keep in mind any box calculator needs to factor in driver volume, bracing, handles etc
You're better off learning to do all that manually Divide litres by internal dimensions in metres as a guide Ie, I'm working on a 100l box before I subtract 10l for all the above to tune it as 90l Baffle is 45cm by 65cm internally 100L divided by 0.45, then by 0.65, gives me my depth of 34.1cm All rough calcs for my purpose, but I'm still learning too |
