  New Posts New Posts RSS Feed - Bull-Nosed Horn Project
_djk_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Topic: Bull-Nosed Horn Project
    Posted: 03 October 2014 at 9:39am
Hi-Fi
 BMS Co-Ax, PPSL with four 8's, vented to 35hz with a Q=2 filter at 35hz.
Edited by _djk_ - 03 October 2014 at 9:42am
djk
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2014 at 10:59am
Look's interesting, tidy woodwork on the horn. Very different.
burningbush View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote burningbush Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2014 at 11:01am
Oh yesss!
Now we are talking.  Looks great, how are the 4x8" loaded?
Post Options Post Options   Thanks (0) Thanks(0)   Quote burningbush Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2014 at 11:02am
The eliptical hf waveguide must have taken a while, how do you do that on a lathe?
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2014 at 1:15pm
There are more photos on the Photobucket page, Looks like the 8's go inside the curved part of the bass horn on a sub-assembly. Looks great, bet it sounds great too :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 03 October 2014 at 11:26pm
"how do you do that on a lathe?"
The ellipses are done on a CNC, glued up with dowel pins, and then the CNC steps are roughed out with a round file, and finish sanded with sandpaper glued to a dowl stick. It is time consuming.
"Looks great, bet it sounds great too :) "
The grille on the HF will wrap around, on the LF it will go back in a deep 'V'.
It has so much less distortion than a single 15 that it's not funny. It sounds like it goes lower, although it doesn't measure any different in the bottom octave (as far as amplitude goes).
djk
Timebomb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Timebomb Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2014 at 12:06am
Looks great DJK!  Really like the extra thick laminateed curve, bet thats solid as a rock.
bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bee Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2014 at 12:23am
very nice job on the curved panel...
Post Options Post Options   Thanks (0) Thanks(0)   Quote _djk_ Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2014 at 9:06am
Nasty phone photo (with grills):
They look and sound great!
djk
R Mogale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Mogale Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2014 at 11:11am
Is this you work Dennis.
MattStolton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattStolton Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2014 at 1:00pm
I thought that the great and the good had a problem with the BMS co-ax drivers - 3rd order harmonics or summit'.
How can you do a super low distortion bass (PPSL), and then use a super high distortion BMS annular ring co-ax driver?
Wink
imageoven View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote imageoven Quote  Post ReplyReply Direct Link To This Post Posted: 04 November 2014 at 1:09pm
Very nice.
Better than the usual car audio!
This page was generated in 0.172 seconds.
