  New Posts New Posts RSS Feed - Poplar ply - any good?
stevie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevie Quote  Post ReplyReply Direct Link To This Post Topic: Poplar ply - any good?
    Posted: 10 October 2014 at 6:07pm
Does anyone have any practical experience of bass cabs made from poplar ply? Do any pro companies use this material for their boxes? The weight savings are attractive but I wonder how they perform in comparison with proper birch.
djyves View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote djyves Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2014 at 8:01pm
I've build a few cabs and cases out of poplar ply. It's much softer and more flexible.
So it will require more bracing, but it is a cheap alternative.
I sometimes use it for modular 19'' racks for amps, effects etc. works fine.
"If brute force doesn't work, you're just not using enough!"
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2014 at 8:15pm
I've done some guitar and Bass guitar cabs out of it. Not sure about heavy subs. I'd probably double it up just to make it nice and heavy. If the end grain doesn't become a problem, it is certainly alright for non acoustic stuff.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 10 October 2014 at 8:44pm
Dynacord use poplar in lot of their boxes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stevie Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2014 at 2:32pm
I was thinking of building a reflex cab using a single BMS 500W 15" driver. I don't think poplar is any cheaper than birch but it's much lighter - which is its attraction. I want to keep cabinet vibration to a minimum. Perhaps extra bracing might do the trick then.
I didn't know Dynacord used poplar. Interesting.
RobinMatrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RobinMatrix Quote  Post ReplyReply Direct Link To This Post Posted: 12 October 2014 at 6:10pm
We use a lot of poplar in our builds, both Italian and Spanish variants, it's more expensive than Birch, but it is light. If you brace it appropriately it is fine.  We have built several hundred poplar cabs the past year ...
Matrix Pro Audio ::http://matrixproaudio.com/"
woody2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woody2 Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2014 at 1:30am
burns well
swan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote swan Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2014 at 6:12am
JBL use poplar ply wood in their PRX range. Very light.
Music is my adiction
bitSmasher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bitSmasher Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2014 at 8:13am
Not very poplar as it seems
jazomir View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jazomir Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2014 at 9:16am
There are several pallets of the stuff  in the Peavey Auction that was highlighted in another thread. (It is referred to as 'popular' ply)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dub Specialist Sound Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2014 at 12:11pm
I have used it before, you can get some good results , bit of extra bracing jobs a gud,un
above all wood burns well to my knowledge....no? , NO perhaps not!!!
Edited by Dub Specialist Sound - 21 November 2014 at 12:12pm
KidCreole View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KidCreole Quote  Post ReplyReply Direct Link To This Post Posted: 21 November 2014 at 12:13pm
No. Should never be used for speaker cabinets. Too light weight.
Mykey Wattco
This page was generated in 0.113 seconds.
