Tapped Horn Build pics |
Page 123> |
tommysb ![]() Registered User ![]() Joined: 24 April 2006 Location: Finland Status: Offline Points: 1036 |
![]() ![]() ![]() ![]() ![]() Posted: 30 March 2007 at 3:07pm |
Started building my tapped horn design prototype, I hope it works!
Anyway, here's some pictures of the magic! ![]() The internal Layout ![]() The curved section at the far end of the horn ![]() Before being glued ![]() From Behind ![]() Preparing the bendy MDF! ![]() About half the clamps in place ![]() I accidentally over tighened the rachet straps and cracked the top left corner ![]() ![]() More of the same! ![]() Going together nicely! ![]() That's it for now! There was some more work done after these....Cutting the baffle, but made a bit of an error and the rebate to locate the driver in was cut too deep...... I've filled it with wood glue and mdf dust.... I hope it works! Next installment tomorrow hopefully! |
nice
Edit: Double post woops!
Edited by tommysb - 02 April 2007 at 2:59pm |
Worked on it again today.
Filling the too deep rebate with PVA and sawdust worked a charm, ![]() ![]() After a rebate had been routered in: ![]() The driver next to it: ![]() Unfortunately, my good router is too big to cut 10" holes, so when cutting the actual hole for the driver, i used my £20 router and it's not as accurate, so the hole is 5mm too big, Grrr! ![]() Here's the curved section without the clamps etc. ![]() ![]() It was quite a hassle making it fit, I forgot to account for the thickness off the material when doing the inner curve, so had to make some approximations, and trim it down a bit! Here it is trimmed: ![]() And the rebate cut for it: ![]() I didn't realise the bendy ply is 2ft wide, rather than 60cm, so might have to change the depth of the cut a bit so all the internals are level for the last panel. Grrrrr! At least it fits in the rebate well: ![]() Here's some mock-ups of roughly what it should be like when it's done: ![]() ![]() ![]() You get the idea! Maybe will finish it tomorrow......We'll see! Peace out y'all! |
login4 ![]() Old Croc ![]() Joined: 03 April 2006 Location: Wales Status: Offline Points: 1552 |
fair play that should sound really nice,
![]() what are the drivers your using? |
CELTIC SUBSONIC SOUND SYSTEMS
philpope ![]() Registered User ![]() Joined: 21 January 2007 Location: United Kingdom Status: Offline Points: 41 |
will be interesting to see results. I remain sceptical about tapping in so close to closed end of horn but I hope you prove me wrong and it works fine.
Phil
The drivers are an autosound called Mivoc 104 I think.
Some more pics. No comments this time, it's late. Except that late speaker building and good speaker building don't go well together! Peace ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Will test it tomorrow when the glue's definately set. |
Insomnia ![]() Old Croc ![]() Joined: 06 September 2005 Status: Offline Points: 1721 |
looking good mate-
thanks for sharing the pics with us
_djk_ ![]() Old Croc ![]() Joined: 23 November 2004 Location: United States Status: Offline Points: 6002 |
Looks like a lot of work on the curved surface that will not make a measurable difference in performance.
djk
bitcore ![]() Registered User ![]() Joined: 12 February 2007 Location: United States Status: Offline Points: 168 |
I think it's nice, I like how this is turning out. He's probably doing better with the wood than I would have. now lets see some measurements! |
Yes my thoughts actually! 2 sheets of bendyMDF = £14, which isn't insignificant on a budget build! Fired it up today, and it's a little dissapointing. Not as sensitive as the big folded horns i have, and not as 'full' sounding. This was designed to be run as a pair though, so the plan at the moment is to knock together another one real quick, without the rebates or curved section, as I already have most of the panels cut for it, should be possible in about a day. Will have a listen with a sine sweep later and try to judge how peaky the response is, and where cuttoff occurs. I hope it's not all been in vain! |
try some different drivers. I have managed a 38Hz cutoff with a 98dB driver. with an 88dB driver you would want a tapped horn about twice the length of the one you have made and be aiming for 20dB cutoff. you are never going to get as much gain with a tapped horn but because it controls the excursion better you can use a more sensitive driver with lower xmax.
Phil
Page 123> |
