B&C MH32 v B&C 12NDL76 |
TONY.A.S.S. ![]() Old Croc ![]() Joined: 21 February 2007 Location: United Kingdom Status: Offline Points: 6878 |
![]() ![]() ![]() ![]() ![]() Posted: 25 April 2007 at 11:41am |
AB.= Compare one with the other best done with a switch over box. SWITCH OVER BOX = Makes AB testing easy. |
ceharden ![]() The 10,000 Points Club ![]() ![]() Joined: 05 June 2005 Location: Southampton Status: Offline Points: 11748 |
How many times have I posted about the 12NDL76?!?
Same as Tony, it's a great driver. Have also done an AB with the 12MH32 and apart from the weight they are practically identical. Sound equally good. TS parameters are almost the same too. Neither speaker does bass, they're upper bass/midrange drivers and very good at it. You can force the NDL76 to produce more bass (using EQ) because it has greater excursion capability. |
mrspock ![]() Registered User ![]() Joined: 16 April 2007 Location: United Kingdom Status: Offline Points: 93 |
Hi what's AB? and what cabs do you use and what bass responce can you get.
Cheers Chris
We use the 12NDL all the time. It is a great speaker. We use it as a bass/mid in 2 way speaker cabs. The only way to choose on the day is to AB them. The overall response will be determined by the crossover. Neos do seem to be more effecient in the mid band compared to their standard counterpart. Edited by TONY.A.S.S. - 25 April 2007 at 3:14am |
Hi has anyone ever used B&C 12NDL76 as ide like to now what it sounds like. Has it more bass responce than the MH32 driver or sound as nice.
Cheers Chris
