HD 215 |
xanderk1203 ![]() New Member ![]() Joined: 20 October 2017 Location: CA Status: Offline Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 20 October 2017 at 8:31pm |
Nothing a bit of delay can't fix haha
dekra54 ![]() Registered User ![]() ![]() Joined: 01 July 2017 Location: Germany Status: Offline Points: 73 |
Yes my originally plan was to go as low and braodband as possible but as i realized and learned later W-Bins sound ... kind of "strange" in the upper regions.
I just digged out the hornresp data for (which i assume ![]() ![]() ![]() Maybe you have some suggestions what i have done "wrong" or shoudl/could change ![]() |
all bass ![]() Old Croc ![]() ![]() Joined: 11 October 2012 Location: the Netherlands Status: Offline Points: 1855 |
the hornpath in your own designs looks a lot longer than the HD15.
Get your free line array plans here!
Thank you for the reply :)
I just wanted to be sure because i build 3 types of cab's (own design) but they were just to complicated to build and I was not very pleased with the sound either. At the moment i just want to build some kicking bass cabinets and thougt the HD15 or the doubled version HD215 would be a great choice ( I will need something for the low end in the future for sure) . I've never heard an Bandpasshorn before but from reading 100s of pages here i think they are the right cabs for heavy Techno but recommendations are always welcome if you have more vesatile suggestions :) Greetings dennis ![]() Edit: added pictures my current version ![]() ![]() Edited by dekra54 - 04 July 2017 at 8:13pm |
bass*en*mass ![]() Old Croc ![]() ![]() Joined: 03 September 2009 Location: "unknown" Status: Offline Points: 4009 |
dennis, the braces are not there to "direct the soundwaves" but there to brace the cabinet and reduce resonances.. btw., unless you really like the bandpasshorn sound using heavy/strong cones i would personally opt for either large front loaded horns or just reflex or hybrids of both :)
for kick duty light and reasonably strong cones sound so much better in bandpasshorns imo.. |
Hello forum,
I'm a long time reader and just have registered because I'm planning to build 4 HD215 with PD1550 which I have laying around for quite some time... . My questions is : Is the panel in the middle really required if i "sandwich" two normal HD15 together ? Obviously you need something to direct the soundwaves to the front but would a V where the two "Horns" start be enough ? Greetings from Germany Dennis :) |
