  New Posts New Posts RSS Feed - Noise power supply switching Crown I-Tech T6000.
KK Audio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KK Audio Quote  Post ReplyReply Direct Link To This Post Topic: Noise power supply switching Crown I-Tech T6000.
    Posted: 03 November 2022 at 1:02pm
Hi, could you tell me how you fixed the problem please. I have an Itech that has the same fault. Many thanks KKAUDIO
Kadro View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kadro Quote  Post ReplyReply Direct Link To This Post Posted: 03 December 2021 at 11:49pm
I am from Uruguay but live here in Brasil, i got more information about this amp
opacheco View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote opacheco Quote  Post ReplyReply Direct Link To This Post Posted: 03 February 2020 at 4:50am
Hi,
Do someone have the Schematics (complete schematics) for this amp?
Thanks
opacheco.
geovanebr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote geovanebr Quote  Post ReplyReply Direct Link To This Post Posted: 24 April 2019 at 6:50pm
Hello Everyone, could someone send me the schematics for it-6000, please?
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 05 January 2018 at 10:19pm
Quote I think I discovered it
Details please or it didn't happen
North Staffordshire
patryk1305 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patryk1305 Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2017 at 6:05pm
Originally posted by nopamp nopamp wrote:
I think I discovered it :)
Turned it on and no longuer makes that "transformer like" noise.
Then share your findings in case others have similar issues EmbarrassedClap
nopamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nopamp Quote  Post ReplyReply Direct Link To This Post Posted: 10 December 2017 at 5:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote nopamp Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2017 at 11:42am
Hello, have you already discovered what is the problem?
I have one unit with same problem that I will investigate this weekend in case I get time.
Sincerely,
Joel
Post Options Post Options   Thanks (0) Thanks(0)   Quote kedwardsleisure Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2017 at 11:59am
I always thought this generation of crowns was just the designer going a little bezerk. Since production is outsourced to China, I guess the number of parts are less of an issue...so why not fill your boots!
A couple of years ago a spilled pint on the amp rack wrote-off an entire stack of XTi's. The high-density boards went off like a box of fireworks and there wasn't alot left.
North Staffordshire
RobinMatrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RobinMatrix Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2017 at 9:49am
Jeezus ... I never bothered to look at this PSU before, but 24 power devices in the PSU?  That's a lot of work to save paying for a decent sized IGBT!
Matrix Pro Audio ::http://matrixproaudio.com/"
mj15015 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mj15015 Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2017 at 8:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mj15015 Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2017 at 8:09pm
as
