Tops on a budget |
Post Reply | Page 12> |
Author | |||
Lovehertz
New Member Joined: 17 May 2018 Status: Offline Points: 4 |
Posted: 22 May 2018 at 5:26pm |
Hi all,
I'm planning on putting together a pretty basic pair of tops on a tight budget and have a few questions. I've shortlisted: 12"s - Eminence Delta 12A (400w) Tweeters - Eminence APT 150V2 (35w) X-overs - Eminence PXB2-3K5 (400w) Both boxes will be connected in parallel and run off a bridged QSC RMX 1450, 200hz and above. 1) Am I making any glaringly obvious facepalm noob mistakes here, re. choice of drivers? 2) Will the APT keep up with the 12", or should I use something with a higher power rating? 3) The Delta has a spike in the response from 2k - 5k. Would crossing over to the APT at 5k instead of 3.5k maybe sound better, and am I right in thinking that would also increase the APT's power handling a little (if needed)? Any advice greatly appreciated. Cheers. |
Dub Specialist Sound
Yes apts better power handling slighty crossed at 5k, but dont forget too the diaphgphms are discontinued....
nickyburnell
Don't wast your time. Buy some used speakers. Put a wanted ad on here with your budget
dylan-penguinmedia
Old Croc Joined: 14 April 2011 Location: Brighton Status: Offline Points: 4575 |
Thanks(1)
look for some Celestion CXi tops...
Well made and cheap, sound good. Then maybe build yourself a sub to go with if necessary. One channel for the sub, the other channel for a pair of tops if you want to go down that route, and a 2 way active xover. Things like the sub and active xover can be added should you want to grow.
Conanski
Edited by Conanski - 22 May 2018 at 8:54pm |
LunchieTey
Young Croc Joined: 06 February 2005 Location: Australia Status: Offline Points: 934 |
Compared to the original idea, you'd almost be better off using a beta12cx and asd1001 and eminences crossover designed specifically for the coax. Reasonably good sound with no guesswork and still quite cheap.
Speaker addict
Hemisphere
Or a Fane Sovereign 12-250TC
79 euros at Thomann, 4-5 weeks stock though..
Edited by Hemisphere - 22 May 2018 at 9:37pm |
Lovehertz
Conanski.
Well. When you put it like that... ok. I'm definitely looking for used tops then I think lol. (Thanks for the schooling. Better to find out now rather than after I've spent my hard earned!) Edited by Lovehertz - 22 May 2018 at 9:42pm |
Lovehertz
Thanks DSS.
Nikky, budget is £300 max. If I can score something better (used) for the same money and less headache then that's ideal. I'll look into it. Cheers for the no-nonsense advice. Dylan, Thanks for the recommendation. I'm really not clued up on what specific models I should be looking at for decent used tops, so if anyone else wants to throw in more recommendations, I'm all ears. |
nickyburnell
Do a wanted ad. You should find a pair of EV SX300 or similar if you are lucky
JonB67
Proel next 12hp seen several pairs available for that and less. B&C neos. Sound good.
nickyburnell
Yep. I paid 400 for 4 RCF Event 1000. Birch cab, obsolete 1" but they all work and 50 quids worth of Beyma will sort them if and when.
