Total Newb looking for help with cabinet design |
teflongrizzly
New Member Joined: 02 March 2019 Status: Offline Points: 4 |
Posted: 02 March 2019 at 7:07pm |
Hi everyone.
I have a Gauss 4583a that I would like to use in a Bass guitar rig but I need to build a cabinet for it. I have tried it in a small trace elliot cabinet but it sounded rather lacking which I think was because the speaker was too small. I'm looking for a little direction into where to look to find/figure out dimensions and specs for a cabinet.
Robbo
Old Croc Joined: 05 December 2005 Location: Shropshire Status: Online Points: 4221 |
Gauss 4583A is a 15" driver that was designed as a subwoofer to be used in large horn loaded PA cabinets so it is completely wrong to try and use it for bass guitar---Do not waste your time as it is totally unsuitable.
teflongrizzly
Thanks for the information. I'd still like to build a cabinet for the speaker. Any information or advice?
teflongrizzly
EDIT/CLARIFICATION: I stated above that I thought the speaker was too small which is incorrect. What I meant was that the volume of the cabinet was too small for the speaker. The trace elliot mentioned above also has a 15" speaker and the gauss physically fit into the cabinet just fine.
godathunder
Old Croc Joined: 19 July 2004 Location: wicklow Status: Offline Points: 1833 |
heres some specs that may help you in making a cab for it
however, robbos advice, above, is probably pretty sound - if you do want to build something for it youll probably want to add a 10" or similar above to give you a bit more articulation
LOUDER THAN LOUD
Chris Grimshaw
Registered User Joined: 10 September 2018 Location: Sheffield Status: Offline Points: 281 |
It'll work fine for bass guitar. I'd probably just build a sealed box in the 50-75L range and call it good. The reason for a sealed box is that the cabinet's air spring will help prevent over-excursion, which can lead to damage quickly. Treat it like the vintage driver it is, don't expect it to shake the whole venue, and it'll do you well. Chris
Quality sound from Sheffield
www.grimshawaudio.com |
