tractrix horn spreadsheet wanted please |
Post Reply | Page 123 4> |
biotec
Old Croc Joined: 07 June 2004 Location: United Kingdom Status: Offline Points: 2932 |
Posted: 05 December 2008 at 5:48pm |
Does anyone have a spreadsheet for calculation the area of a tractrix horn with varying distance from the throat so that I can start designing a horn? Something much like centauri’s spreadsheet for bass horns would be great but for tractrix instead. If no one has one does anyone have the formulas for calculating the expansion myself? I will no doubt be making them out of rings of MDF and sanding them smooth. Thanks, Nick |
S DeXter
Young Croc Joined: 12 May 2008 Location: Moon Status: Offline Points: 1268 |
Is the tannoy a tractrix for sure? What about Oblate spheroid, i can get you the formula for that....
S DeXter
Heh good old google....
http://www.geocities.com/agalavotti/tractrix.htm i think the tractrix looks a bit more curved than the tannoy, i may be wrong tho.... |
Deadbeat
Old Croc Joined: 12 March 2008 Location: Singularity Status: Offline Points: 3167 |
Tannoy is definitely OS...
Tractrix would look a bit different. If you want OS, I believe S DeXter and I have spreadsheets on the computer. I use the Melhuish calculator for tractrix, it is available at rocketsciencecanada.com If you want any help, give us a shout, I've made round horns before. |
Away on extended leave.
minaximal
Old Croc Joined: 26 September 2004 Location: United Kingdom Status: Offline Points: 1780 |
i would go for the os option if you can as a bit more fun for a home hifi project, but horn response will do tractrix, you just need to dump the the numbers as a .scr into solidworks or autocad, i could also do the same with aj horn.
Paulo Duto
Registered User Joined: 06 January 2005 Location: Brazil Status: Offline Points: 123 |
Hi
Volvotreter site in the download section has what you are looking for.
Also reproduces some Bruce Edgar articles on tractrix subject...
Regards,
Paulo Duto
mykey
biotec
cheers for all the help. Deadbeat or Dexter can you link me up with the OS spreadsheet? I'll PM you my email address if you cans end it over.
What are the basic differences in dispersion, cut-off and response between OS and tractrix horns and what makes one more suitable than the other for hi-fi use?
Deadbeat
Will do. PMs now empty.
Tractrix was used to create a hemispherical wavefront at the mouth (in comparison to exponential, etc) and so reduce reflections. This only happens in round horns really, mind. You don't really have directivity control in a round horn. Look at polars. You can superimpose it onto a radial horn or diffraction slot, or Mantaray, but it's a bit pointless imo - you lose the no reflection effect to gain a bit of nominal dispersion (in the biradial case). This is a part of old school horns which were primarily designed to load the compression driver, to couple it with the air. Will post again on OS and conical horns, have to go. |
darkmatter
If you're making OS waveguides for a BMS coaxial gimme a shout, especially if you're getting anything machined, cos getting another pair might reduce costs and I reeeaally want some!!
Don't know of any proper OS waveguides in this country so I've never heard them, but I'm curious. An OS waveguide would supposedly suffer from less distortion and plugged with foam you can reduce high order modes. Make it nice and big to get a 1K crossover with polar response matching the horn / driver below it and you're on to a winner apparently. So does anyone know what the exit angle on the BMS co-axs is? As a rough guide, a 15" waveguide on a 1" exit CD will give a 900Hz x-over. At this size it matches the polar response of a direct radiating 15". http://www.gedlee.com/downloads/Cum%20laude.pdf |
davey t
Young Croc Joined: 11 March 2004 Location: Bristol UK Status: Offline Points: 1428 |
it was nice hearing those tannoys at plaza. The guy was really sound too - gave us free beer and t-shirts! It definately wasn't tractrix, looked almost conical but probably OS as you say.
I thought about looking into the bms coax drivers but read a few off-putting reviews on psw or diy audio forum. But then again it all depends on the waveguide and crossover etc. Good luck, i can't wait to see some of these diy. |
Deadbeat
Waveguides. They aren't as much concerned with loading - but directivity. The main difference between a WG and a conical horn is that the conical one does not alter the wavefront. Other WGs like the OS turn the planar wavefront into a round one, then continue roughly conically.
I suggest you read the geddes' summary linked as well. It summarizes HOM and his approach. Basically: 1) The room is the reason you want CD (in his paper) 2) HOM contributes to the horn sound, these are waves that don't propagate down the horn. 3) The OS Waveguide is the best way to get a planar wave to a round one without much HOM 4) the plug attenuates HOM generated by the comp and the WG The only thing is that...while a lot of comps are designed to give a planar wave...some don't. For example, I think Danley use a BMS that gives a pretty round wavefront in one of their conical horns. Still the benefit of lessened HOM. You can also see the new celestions with their 'curved wavefronts' which may be good for a conical, no? The reason why Geddes' doesn't like the BMS coaxes is because they have the xover frequency in the wrong place. Edited by Deadbeat - 09 December 2008 at 2:39pm |
