Transducer ID EAW 15" 804052 |
bob4
Old Croc Joined: 29 February 2004 Location: Finland/Germany Status: Offline Points: 1842 |
Posted: 01 March 2021 at 7:53pm |
As per the title, we have single 15" woofer, EAW badged, P/N 804052
Apparently a B&C OEM, is it something very special, or just a rebadged stock model? Cheers Bob
Old Croc Joined: 02 April 2004 Location: United States Status: Offline Points: 5172 |
EAW used a wide variety of brands (RCF, Eighteen Sound, Eminence) so there is no guarantee it is B&C. Contact EAW or post a photo and we can all guess what it is. However, without the TS Parameters, your question will still go unanswered if you really want to design a box around this driver. As a matter of fact. Why not just download REW and measure the driver yourself? Best Regards,
Edited by Elliot Thompson - 01 March 2021 at 11:04pm |
bob4
Looks exactly like this....... I do have REW installed, and i have measured T/S before, but the point is, i would like to know if this is a rebadged stock driver. Given the age of the driver, it might also be obsolete in the worst case. I see no need to look for a needle in the haystack, if i can ask "needle merchants" and professional seamsters Last time i asked for EAW drver ID on here, i got a reply, albeit i was asking about a compression driver... |
sgarfa
Registered User Joined: 10 December 2013 Status: Offline Points: 101 |
looks like a l15 554k
Definitely RCF. That driver should be around 30 years old. Since EAW had a lot of control over RCF in those days, chances are, it may be a custom design aimed for a particular box.
Best Regards, |
bob4
Thank you gentlemen....
