  New Posts New Posts RSS Feed - Trapiziod XTro
Trapiziod XTro
jethrocker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2006 at 8:56pm
Yeah..but what happens to the bit where the top driver in the kick section sits behind the 8" section...you just going to box it off and accept the useless space?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 25 October 2006 at 8:58pm
oh, and also.. Are you still going 5 way? Or is it just subs, xtro kick style/  mids/tops?
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2006 at 6:55am
sub kick mid comps and bullets.... so yeah 5 way
insert silly sentence here
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2006 at 7:08am
Originally posted by doober doober wrote:
Returning to the original topic there's a trapezoid x-tro(ish) box here. Can't understand the discussion (slight language problem) but there are some good pics and drawings.
Regarding seperate boxes, I have been thinking a punisher size kick bin containing 2x15" x-tro style or 1x15 bent horn could be very usefull as it will stack well amongst/atop punishers. Above these could be a much smaller and lighter (easier to lift up high) 8"+1" which could be made trapezoid. Maybe something like this? if you want 2x8"
realy like the look of the pics from that first link but i cant even start when it comes to languages......
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 15 November 2006 at 12:25pm
Coner..still curious, how could you remove the 8" section and make the cab smaller?
irate-drss View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irate-drss Quote  Post ReplyReply Direct Link To This Post Posted: 07 December 2006 at 1:12pm
yeah that mid top on that dutch page is pretty damn sexy! anyone speak dutch or got anymore info on them?
Dayliterobbery Soundsystem
Jeroen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeroen Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2006 at 10:34am
Hi,
I am )jeroen(, the guy from the dutch forum. I am thinking about making a prototype soon. This is the last version of the design:
2x12" 18Sound 12ND930
1x8"   B&C 8PE21
1x1"/1.4"
The design is made for the 18Sounds as low/mids, most of the other 12" speakers won't fit.
JVsound
Nigey-C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nigey-C Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2006 at 2:25pm
very nice design.
Do you know what the Reponse will be like from it? Is it designed with being used with a punisher?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2006 at 3:43pm
aha i was viewing this on the dutch forum a week or so ago. but i couldnt work out much but i did look at the varius designs.....
id lik to see the plans
Edited by Markk James - 11 December 2006 at 3:45pm
kevinmcdonough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevinmcdonough Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2006 at 8:09pm
Hey all
I babelfish-ed the pages of that forum, and although it only made marganally more sense (lol some of the translation was quite comical ) I am very interested in this design.
Phil Dekked, of your about would you mind speaking to your pals at NCA who import the 18 sound drivers, and see what price they can get the ones for this design for ( 2 x 18 sound 12ND930 instead of the normal punisher 15", plus the normal mid and high sections) and see how it compairs to the fairly steep cost of the normal punisher drivers?
And a question for Jeroen if you dont mind answering, what kind of dispersion does the cabinet have, and does it array well along the angles of the trapezoidal sides?
kev
Mircea Bartic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mircea Bartic Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2006 at 5:20am
kev
it looks like the dispersion will be about the same as for the original X-tro
about 60x40 above 2Khz probably
unfortunately I don't think this one it will array properly either, but will be a lot better in terms of comb filtering than the xtro
the MF will  overlap either way you put it = comb filtering is inevitable
the HF will have the same problems too, + some more, because it will not be close to another, thus it wil not sum corectly, and there will be no hf gain, just wider dispersion
anyway I like the design, I think is the furthest we can go with the curent technology.
Please note that the mid section can't be made to work perfect without having a hyperbolic reflector in it , to create a virtual sound source behind the enclosure so the dispersion could be corectrly controlled.
I saw this being implemented somewere, but in our case I don't think is feasable.
Edited by Mircea Bartic - 13 December 2006 at 3:30am
Ex Nexus_3
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevinmcdonough Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2006 at 5:05pm
yeah, pretty much what i had thought, I was just hoping i may be wrong
Still a very interesting design though, and i thnk the double 12" section may work out a good bit cheeper than the double 15" one on the original.
with regards to the parabolic bit you mentioned, i think i have an idea of what you mean but would be interested in some more detailed explination if you don't mind.
k
Edited by kevinmcdonough - 12 December 2006 at 5:08pm
