  New Posts New Posts RSS Feed - Triangle Scoop
Triangle Scoop
Jhodas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jhodas Quote  Post ReplyReply Direct Link To This Post Posted: 10 February 2008 at 11:44pm
And there I was thinking scoops only work on rolling basslines. Tony, A.S.S. gear will never cease to amaze me.
TONY.A.S.S. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2008 at 12:11am
Correction to my last post. It's the Reflekta MX system that's in the Astoria not the RX.
Freddy Hopper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freddy Hopper Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2008 at 8:14pm
Tony, do you find the trapezeiod shape box, are inferior to the traditional rectangle/cuboid/box shaped whatever the term,   I notice the BS1200s are rated down to 40Hz where the MX1200s(trapezoid shape) only play down to 50Hz, I know the reason for the MX is to cater for line arrays but is it harder to design, does it have more bad points????????
Fill us in.
TAIL LIFT
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2008 at 10:48pm
One fundametal reason for the different response is the size. The mx1200 is a lot smaller than the BS1200. Although the horn path lengths are similar the volume in the horns is different.
Unfortunaly, when I did the MX system I was influenced by the acceptable size situation. Everyone had boxes this size, so I went with it. It took ages for me to get a satisfactory response out of the MX1200.
When I did the BS1200, I wasn't restricted by size so much and I built it as a stand alone bass cab.
When it came to the MX system. After I was satisfied with it, the response was never going to be a problem, as the 21" sub was always going to be part of the system.
I know this is stetching the point, but the only thing that matters with a lot of sound is the size of the cab. Being trapezoidal has nothing to do with it. After all, it would be possible to build a trap cab that was bigger all round than a square one.
I don't think any of those systems have bad point. The MX system took the longest time to develope, Where as the BS1200 was visulized, with one drawing and built straight away. It was the same with the old 121. It was easy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Freddy Hopper Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2008 at 11:57pm
I have two MX1200s that I haven't loaded yet,  cannot afford the drivers....  I want to load with the original 1550s that were in the box.  I do however have a couple of eminece kiomax in some 15" scoops,  I might see how they sound in it.
TAIL LIFT
mykey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mykey Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2008 at 4:58am
Originally posted by biotec biotec wrote:
noise control did the ones in the carnival photos I think
so NCA built these?
927
Post Options Post Options   Thanks (0) Thanks(0)   Quote TONY.A.S.S. Quote  Post ReplyReply Direct Link To This Post Posted: 20 February 2008 at 8:27am
Also in the shot , an example of the first wooden bar handle on the Q system cabs.
