TS Parameters of Indian Driver |
Author | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
carumartins
Registered User Joined: 23 May 2006 Location: India Status: Offline Points: 30 |
Posted: 26 May 2006 at 12:36am |
Tom Umney
Registered User Joined: 26 February 2004 Location: United Kingdom Status: Offline Points: 4954 |
Won't work well in the X1, xmax is too small. Driver will be physically damaged if you push it in the X1. It will work in the 184 sub or the 186 horn or the super scooper 18.
Mircea Bartic
Old Croc Joined: 18 February 2005 Location: Romania Status: Offline Points: 2582 |
toxic, x-max is not the same as X-mech
remember that Sd-18 has exactly 5 mm x-max, and it works verry well in the x1 the driver could verry well work in the X1 carumartins, please download a copy of winisd from www.linearteam.org , and simulate the x1 with your driver at a closer look, your driver seems like an exact copy of sd18 (the recomanded driver for X1) Edited by Nexus_3 - 28 May 2006 at 2:59pm |
