  New Posts New Posts RSS Feed - TSP measuring?
TSP measuring?
teeth View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Topic: TSP measuring?
    Posted: 11 September 2022 at 10:32am
Hi there, wondering if someone can recommend me a service or person that can accurately measure the T-S params of a speaker.
I have not heard of such a service before but assume it exists?
Thank you.
fatfreddiescat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fatfreddiescat Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2022 at 1:08pm
Dayton DATS V3 are around £150 and very easy to use or REW, a resistor and a PC soundcard. Then just need to knock up a solid fixing for the driver.
kipman725 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kipman725 Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2022 at 5:23pm
if your measuring subwoofers you may want to use a power amplifier to obtain sufficent drive voltage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote teeth Quote  Post ReplyReply Direct Link To This Post Posted: 11 September 2022 at 9:43pm
thanks guys
to be clear i would like someone else to do it, who has done it repeatedly, has a set up geared up for it and can maybe produce a nice document with it too.
interested in OEM so want to have a bit of ammo for the manufacturer
Post Options Post Options   Thanks (0) Thanks(0)   Quote kipman725 Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2022 at 3:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote kipman725 Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2022 at 3:23pm
Failing that try the classifieds in voice coil magazine (free subscription).
Post Options Post Options   Thanks (0) Thanks(0)   Quote toastyghost Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2022 at 10:23am
Originally posted by teeth teeth wrote:
thanks guys
On a smaller or DIY scale, Josh Ricci of data-bass.com has a proper setup and his data is generated in compliance with the typical standards.
Otherwise you might want to speak to Geoff Hill and find a user of his tetrahedral chambers which is local to you:
https://www.hillacoustics.com/
