TSW-718 vs USB Sub |
Page <1234> |
Big-mach
Joined: 27 October 2009 Location: Copenhagen Status: Offline Points: 13 |
Posted: 27 October 2009 at 2:37pm |
Im looking for plans, so i can get 'en build here in Denmark....I would prefer the tsw-718, because i can rent additional if i need em...the outher meassurements are on the turbosound webside, then its just the inside i have to worry about..:-)
james folkes
Joined: 08 January 2005 Location: United Kingdom Status: Offline Points: 3064 |
Posted: 27 October 2009 at 3:58pm |
well, the 718 is a current turbosound product, so even if someone can give you the plans they probably shouldn't, and if they post them here one of my colleagues or i will hide or delete the entry... them's the rules innit.
if you have your heart set on that cabinet then you might just as well go and rent one and measure it up, although you won't get the correct drivers for it so they won't be the same as genuine ones when you do rent in additional boxes... go your own way, don't be some second rate imitation of a big brand-name system: whip up some es18bph doubles if you want plans for a 18" bandpass horn with vaguely known pedigree, load with p-audio 650el or perhaps celestion ftr (not sure what's available and cheap for you), rinse and repeat. james.
mardy hippy.
Quantum Sounds
Joined: 26 December 2008 Status: Offline Points: 462 |
Posted: 27 October 2009 at 4:11pm |
why coppy a 718 and put the wrong driver in them? they do not sound good, use a plan designed for an avalable driver!
Big-mach
Posted: 27 October 2009 at 4:24pm |
Ill have a look at the es18php... perhaps modify it the right size and drivers...
dj-panoramix
Joined: 28 September 2005 Location: France Status: Offline Points: 462 |
Posted: 27 October 2009 at 4:32pm |
i didn't see that, then of course go for esbph or usb(in simulation esbph don't go much lower), simulation single usb vs single esbph in 0,5PI(so similar to 2 usb vs 4 esbph):
Big-mach
Posted: 27 October 2009 at 8:14pm |
I cant find the es18bhp plans, link pease?
dj-panoramix
Posted: 27 October 2009 at 8:35pm |
Father-Francis
Joined: 24 October 2007 Location: Kenya ,Denmark Status: Offline Points: 2758 |
Posted: 28 October 2009 at 5:32pm |
give mig et opkald jeg i København.
Francis |
Big-mach
Posted: 29 October 2009 at 6:45am |
Jamen hvad er dit nummer?
cnics
Joined: 23 March 2005 Location: Worksop Status: Offline Points: 676 |
Posted: 02 November 2009 at 1:36pm |
Technically the 718 isn't a current product and hasn't been for some years. It doesn't and shouldn't change the rules though!
Rob Beech - Technical Director - Cnics Audio
tv00
Joined: 10 August 2009 Location: Denmark Status: Offline Points: 1886 |
Posted: 28 April 2016 at 10:27am |
I got 8 of the copies, width has been extended, so in order to keep proper compression I should extend the horn inwards and I end up with a longer horn, same compression.
However the question is if the tsw-718 has the magnet in the front chamber like the tsw-218, I don't think they did that yet, but I'm not sure? |
cravings
Joined: 30 January 2007 Location: Ireland Status: Offline Points: 7507 |
Posted: 28 April 2016 at 10:42am |
magnet in the rear chamber in my 718s.
Page <1234> |
