  New Posts New Posts RSS Feed - turbo tse 2x15
turbo tse 2x15
hektik View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hektik Quote  Post ReplyReply Direct Link To This Post Topic: turbo tse 2x15
    Posted: 12 February 2007 at 10:33am
plans wanted
Static Age View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Static Age Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2007 at 11:05am
just stick two of these side by side http://www.speakerplans.com/index.php?id=hd15horn
Post Options Post Options   Thanks (0) Thanks(0)   Quote hektik Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2007 at 12:26pm
i want o build turbo copys not hd's
Hugo Biermann View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hugo Biermann Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2007 at 3:45pm
Then make them look like these.
Tom Umney View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Umney Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2007 at 3:47pm
HD215 will be the closest you can build.
There must be plans for the Turbosound TSE 2x 15 somewhere though. As some cheeky bugger on ebay has made some.
Looks very very simular to a HD215 though [2 HD15's joined together].
If you ask kindly, he might give you the plans.
Robbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2007 at 3:51pm
HD15 is an exact copy of a Turbosound TSE115 except for the little bracing bits,so as Static Age said--Just put two of them together and you have a TSE215----just look in the Turbound Legacy section of their website for the TSE115 specs as these throw up the specs of the TSE215 also and you will see what we are on about.
jethrocker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jethrocker Quote  Post ReplyReply Direct Link To This Post Posted: 12 February 2007 at 7:56pm
TDA, a member here also has a 15" bandpass horn hybrid design.. it looks more like the turbosound design, with a two peice angled flare. Have a search, or PM him.
matt andrews View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matt andrews Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2007 at 3:36am
HD15 is not an exact copy of the TSE115, the TSE is slightly narrower.
Mark James View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark James Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2007 at 7:35am
sellenium hb1505d1 fairly similar,,, very kicky too!
insert silly sentence here
Post Options Post Options   Thanks (0) Thanks(0)   Quote hektik Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2007 at 2:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote hektik Quote  Post ReplyReply Direct Link To This Post Posted: 13 February 2007 at 2:56pm
thats where i saw them ...didnt think of contacting him ...doing it now
el chupacabra View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote el chupacabra Quote  Post ReplyReply Direct Link To This Post Posted: 16 February 2007 at 12:26pm
he was selling them on here before christmas. 'evolution' if i remember right.
