  New Posts New Posts RSS Feed - Turbosound parts
Turbosound parts
AncientTurbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AncientTurbo Quote  Post ReplyReply Direct Link To This Post Topic: Turbosound parts
    Posted: 12 September 2023 at 11:36pm
New to this site, but very old to Turbo. Bought my first TMS-4 pair in 1986 (?) or 7(?).
And thats my problem.  Getting replacement parts.
Need to replace a CD102 diaphragm.  I've done this in the past with RD102, or RD 102 equivalent.
Now I am having a real problem sourcing them.
The one I just ordered on Amazon doesn't fit.
Anyone have a line on good sources for ancient Turbo parts?
madboffin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 14 September 2023 at 5:08pm
The CD 102 was a Beyma CP-350, but note that it was the 16 ohm version (not 8).
You should be able to get diaphragms, but they are likely to be from after-market manufacturers as the originals have been discontinued.
For information:
CD-101 =  Beyma CP 300
CD-102 =  Beyma CP350-16
CD-182 =  Beyma CP350-8
DC-103 =  Electrovoice DH3
Post Options Post Options   Thanks (0) Thanks(0)   Quote AncientTurbo Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2023 at 7:15am
Thanks for the input.  Definitely is the Beyma CP350-16.
The aftermarket place I bought the replacement from, which looks like the only seller on Amazon or Ebay, sent one that did not fit.
Hoping they just sent an incorrect aftermarket version, and that they'll send the correct one upon return.
Again, thanks for your help.  Im not ready to get rid of these boxes!
Digbethdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Digbethdave Quote  Post ReplyReply Direct Link To This Post Posted: 16 September 2023 at 9:20pm
Maybe time to update the HF
Post Options Post Options   Thanks (0) Thanks(0)   Quote madboffin Quote  Post ReplyReply Direct Link To This Post Posted: 17 September 2023 at 10:38pm
Time to update my previous message, the last line should have read "CD-103" but you probably knew that anyway...
It's worth keeping yout TMS4's working, a classic one-box system from the boys at Partridge Green! (I worked there for a while).
Post Options Post Options   Thanks (0) Thanks(0)   Quote AncientTurbo Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2023 at 3:10am
It might come to that.
Robbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 18 September 2023 at 10:05am
Thinking back to when we had loads of Turbosound---we came across a problem fitting some replacement HF diaphragms to TSE111 and TMS4s whereby we had to remove certain locating pins on the diaphragm mounting flange so that they would fit into the driver correctly---IIRC they were either genuine Beyma or aftermarket parts that we had the trouble with.
This page was generated in 0.189 seconds.
