Turbosound TQ440 |
Post Reply | Page 12> |
Marios
Young Croc Joined: 20 July 2007 Location: Manchester UK Status: Offline Points: 599 |
Posted: 19 February 2015 at 8:39pm |
Looking for a pair or two of these. Doesn't matter if they are the powered versions or not.
MGS Productions
SoundsUnlimited
Registered User Joined: 29 April 2007 Location: Surrey Status: Offline Points: 359 |
I Have a pair of 445 if that's any good to you?
Timebomb
Mate of mine has some TCS-612 for sale in Manchester there quite similar
http://www.xclused.com/dati/prodotti/allegato_201106270332_tcs612.pdf Think hes got the controllers and some bass bins for them too. |
AvLee
Young Croc Joined: 01 June 2010 Status: Offline Points: 1196 |
I'm still after a reasonably priced pair of TQ-425SP subs to match my other pair and 4x TQ-440SPs that I have!
soundguymatt
Young Croc Joined: 25 August 2009 Status: Offline Points: 688 |
how many TCS-612 do they have?
Matt |
Timebomb
I think hes got 4 but its probably best to PM Ed his profile is http://forum.speakerplans.com/member_profile.asp?PF=10626
Cheers James |
Marios
Hello, thanks for the replies. I don't think a 445 will work. Ideally i just need to expand on the 440s we have. Is the 445 the same box with updated drivers, or am i wrong?
I've only seen one TQ-425SP box close by and thats used at the Ritz in Manchester. |
MGS Productions
SoundsUnlimited
The 445 is basically the same box, it has the same drivers as the 440, it just had an updated horn flare.
Djdarch
Old Croc Joined: 10 November 2005 Location: Newark, Notts Status: Offline Points: 1989 |
yeah the 445 has a better horn flare in the middle of the 12" for the HF the can be retro fitted to make 440's 445's . the kit is expensive for what it is though IIRC
deja-ibiza
Young Croc Joined: 09 September 2008 Location: Guildford / Ibz Status: Offline Points: 770 |
All 440s came with the EV HF - Turbosound CD-103
Early 445s also came with CD103 HF, but then changed to a custom driver, the CD-114. The 6.5" Mid remained the same throughout. The 12" is the LS-1214 ,and is essentially the same driver throughout but the 445 used a slightly different variant called the LS-1214H which, as Djarch has pointed out, has a different flare. The actual 12" cone is identical. On the self-powered boxes, the amp and signal processing is quite different. The 440s used modules built by Powersoft (apparently), and the signal processing is fixed by an internal card. The 445s have an amp module called the 'X-Pod' built by UK company Linea Research. They are smaller and lighter than the Powersoft modules due to their class D design. These modules also have full on-board user-config DSP and network capability. Edited by deja-ibiza - 23 February 2015 at 3:14pm |
Djdarch
i'm pretty sure the 445 have an RCF 1" this must be the cd114
AvLee
When my 4x TQ-440SP's are fired up together they sound the bollox! Best compact 3 way I've heard!
