  New Posts New Posts RSS Feed - turbosound tse 112
turbosound tse 112
hibbert261 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hibbert261 Quote  Post ReplyReply Direct Link To This Post Topic: turbosound tse 112
    Posted: 08 January 2016 at 9:51pm
Hi all.Can anybody on here please help me out as im looking for the design spec/ pdf for the TURBOSOUND TSE 112 10" mid cabinet.cheers.Smile
Robbo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2016 at 11:16pm
TSE112 is a 12" mid/hi cabinet---I think you are probably after information on the TSE111 which is the 10" and more common version.
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 08 January 2016 at 11:52pm
IS there a tse-112?
shagnasty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shagnasty Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2016 at 4:50am
I think he mean the 2x10" with a V2 device (top of a V2 TMS-3).....
Nothing TSE had a 12" in the the best of my knowledge...
Plans are useless the mid his section is pretty much "skeletal" the 2 10" are hard coupled the mid devices (PD load only as far as I am aware so LS-1004) and you need an Turbo horn with a V2 device, the CD-102 sounds sweeter (Beyma) but CD-103 (EV) is in real terms indestructible unless you are a tw*t
The box rocks, but is not a nice thing to deploy given the extreme SPL and the less than impressive flying options...
Install on I feel!!!
Plan is buy drivers, buy wave guides, buy back chambers, build crate to hold above!!!!
James Tengo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Tengo Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2016 at 8:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote James Tengo Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2016 at 8:23am
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2016 at 10:32am
I still see no information on a tse-112?
The ebay-link doesn't work, but people can be wrong on ebay.
I know the 211.
I was thinking if 112 could mean 1 pcs 10" and a 2", 111 is 1pcs 10" & (1) 1" 211 is 2 10" and (2) 1"...
Edited by tv00 - 09 January 2016 at 10:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robbo Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2016 at 11:35am
From what I can remember the TSE112 was just like a TSE111 on steroids---It was fitted with a PD12" driver with a decent sized magnet and a larger 1.5" HF driver instead of the V2 device that James mentioned above.
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2016 at 12:03pm
Never heard about it, but to be honest I really doubt it, because all tms / tse horns came out of the same mold & had the same drivers (ls-1001/1002/1004 fits same horn)
Strange if they've developed something that never really went into production.
Wasn't it the flash / floods coming right after tms/tse?
Both series sold the same horns in thousands, so I doubt there was a secret horn in between...
-But you never know, I was quite surprised to find my TFM-2 "turboconcentric" cab!
Jimmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jimmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2016 at 12:44pm
Very similar to the Martin F1 mid top by the sounds of things..
Dubbed-up View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dubbed-up Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2016 at 1:38pm
Not very clear but 100% tse112
tv00 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tv00 Quote  Post ReplyReply Direct Link To This Post Posted: 09 January 2016 at 3:09pm
AMAZING!
The cd-horn sure looks more like the tse-211 dual 1" horn (higher)
I can't seem to read the text, but if it's a 12" I'd expect a lower xover, perhaps it's the same 10"?
Edited by tv00 - 09 January 2016 at 3:18pm
