  New Posts New Posts RSS Feed - Tutorial on Loading the PD 186, Please?
_banksy_ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote _banksy_ Quote  Post ReplyReply Direct Link To This Post Topic: Tutorial on Loading the PD 186, Please?
    Posted: 21 March 2010 at 11:05am
Hi,
I have the plywood routed out to the correct size so that the 186's foam circle rests in a perfect position around the edge of the hole.
Now when rear loading I just need to know which holes to bolt through, there is six holes for bolts and i think another six holes that are covered with foam on the speaker side, if using t nuts and bolts is the six holes enough to support it? any pics would help.
cheers
BreakBeat!
RUS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RUS Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2010 at 11:10am
go though the six outside holes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote _banksy_ Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2010 at 11:25am
Thanks,
So should I use M8 or M6 T-nuts and bolts?
BreakBeat!
RUS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RUS Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2010 at 11:32am
you should use m6.
Saul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saul Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2010 at 12:23pm
Originally posted by RUS RUS wrote:
you should use m6.
actually i think pd186 chassis take M8 bolts.
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2010 at 12:39pm
not quite, the holes are just less than 8mm, i used m8's to mount some of mine and had to drill them out a bit. m6 and a washer will do fine.
Saul View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Saul Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2010 at 12:45pm
hmm thats odd - when ever ive mounted a PD1850 ive managed m8? oh well....
Post Options Post Options   Thanks (0) Thanks(0)   Quote _banksy_ Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2010 at 12:54pm
Yes actually M8 is the correct size for the pd 186
BreakBeat!
cnc123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cnc123 Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2010 at 11:17pm
m6 has a braking strain of aprox 1/4 ton 4 is enough to buckle any chassis
pd use to put m8 machine bolts like hex heads, in the carton
a bit of marketing   me thinks
+ m6 you can be a dork on the drill
+ you can fit many other spks (but only if you can drill on centre)
