TW AUDIO T24N |
Page 12> |
lickweed ![]() Old Croc ![]() Joined: 02 May 2009 Location: leyton Status: Offline Points: 2489 |
![]() ![]() ![]() ![]() ![]() Posted: 27 November 2020 at 10:00pm |
Hi
Anyone used these ? Looking for opinions , the weight is only 33kg , my back would be very happy
http://www.liquidsound.co.uk/
FOO ![]() Young Croc ![]() ![]() Joined: 23 December 2018 Location: Denmark Status: Offline Points: 755 |
Great box!! They sound lovely and can really hand out some good SPLs.
Compact, light'ish and a powerfull. You Will not be disappointed with them
![]() Edited by FOO - 27 November 2020 at 10:21pm |
Earplug ![]() Old Croc ![]() Joined: 03 January 2012 Location: Europe Status: Offline Points: 7100 |
Yup. Excellent cab. The designers come from d&b audiotec - and it shows. ![]() |
smitske96 ![]() Young Croc ![]() Joined: 16 February 2016 Location: The Netherlands Status: Online Points: 1039 |
Indeed a very nice box, the only thing to keep in mind is what you put under it.
It does not really have a lot of 'balls' down low.
Yes ,
Edited by lickweed - 14 March 2023 at 6:29pm |
Two T24n side by side. Sitting ontop of a B30 each. And a BSX on its side down at the bottom. Off you go
knet94 ![]() Young Croc ![]() ![]() Joined: 31 March 2008 Location: NW London Status: Offline Points: 1487 |
The specs say the frequency range is from 65hz to 18,000hz. How is 65hz not ballsy?
Look at the production partner test
MarjanM ![]() Old Croc ![]() ![]() Joined: 10 February 2005 Location: Macedonia Status: Offline Points: 7745 |
My problem with that box is the high crossover point. 1700Hz is way too high.
Thats indeed an odd one. Looking at the graph, something like 1-1.2 kHz would be more suitable.
That really isnt a issue. They sound just fine All the way up there. But pull it down to 1200-1250 and you get bit more crisp and controlled sound image.
I have tested them extensively at my shop. They are good, but too compromised for my liking.
They have passive crossover inside. So using them in passive mode makes them sound a bit weird to me. It is maybe only my ears that are used to HF devices crossed at 800Hz or so.
Page 12> |
