  New Posts New Posts RSS Feed - TW AUDIO T24N
TW AUDIO T24N
lickweed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lickweed Quote  Post ReplyReply Direct Link To This Post Topic: TW AUDIO T24N
    Posted: 27 November 2020 at 10:00pm
Hi
Anyone used these ?
Looking for opinions , the weight is only 33kg , my back would be very happy
http://www.liquidsound.co.uk/
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2020 at 10:20pm
Great box!! They sound lovely and can really hand out some good SPLs.
Compact, light'ish and a powerfull.
You Will not be disappointed with them Smile
Edited by FOO - 27 November 2020 at 10:21pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earplug Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2020 at 6:28am
Yup. Excellent cab. The designers come from d&b audiotec - and it shows.   Thumbs Up
smitske96 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2020 at 10:34am
Indeed a very nice box, the only thing to keep in mind is what you put under it.
It does not really have a lot of 'balls' down low.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lickweed Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2020 at 1:37pm
Yes ,
Edited by lickweed - 14 March 2023 at 6:29pm
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2020 at 2:17pm
Two T24n side by side. Sitting ontop of a B30 each. And a BSX on its side down at the bottom. Off you go Clap
knet94 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote knet94 Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2020 at 4:30pm
The specs say the frequency range is from 65hz to 18,000hz. How is 65hz not ballsy?
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2020 at 4:40pm
Look at the production partner test Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2020 at 5:13pm
My problem with that box is the high crossover point. 1700Hz is way too high.
Post Options Post Options   Thanks (0) Thanks(0)   Quote smitske96 Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2020 at 5:58pm
Thats indeed an odd one. Looking at the graph, something like 1-1.2 kHz would be more suitable.
FOO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FOO Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2020 at 6:24pm
That really isnt a issue. They sound just fine All the way up there. But pull it down to 1200-1250 and you get bit more crisp and controlled sound image.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MarjanM Quote  Post ReplyReply Direct Link To This Post Posted: 29 November 2020 at 3:27pm
I have tested them extensively at my shop. They are good, but too compromised for my liking.
They have passive crossover inside. So using them in passive mode makes them sound a bit weird to me.
It is maybe only my ears that are used to HF devices crossed at 800Hz or so.
