tweeter wiring |
Daganjah
Registered User Joined: 29 June 2020 Status: Offline Points: 15 |
Posted: 01 July 2021 at 2:19pm |
hello everyone
im building a mid top speaker with 1 12״ woofer 8ohm
1 2״ tweeter 8ohm 2 super tweeters 8ohm with a passive crossover i want to know what would be the best way to connect the tweeters to my amp (i use a separate amp for the 12״ woofer) thank you! |
Conanski
Old Croc Joined: 26 January 2006 Location: Ottawa, Canada Status: Offline Points: 2537 |
With speaker cable same as you do for the 12".
I suspect there is more to this inquiry that you have not articulated but I'm not going to guess
Daganjah
thank you fro the quick answer
i think i wasn't clear enough i meant to ask what would be the best wiring for 1 amp channel? do i connect them in parallel or in series? |
Conanski
What are you using as a crossover between the 12 and CD? So all 3 high frequency drivers on 1 channel right.. easy enough.
You said you were going to use a passive crossover for those so it will split the signal into low and high outputs, low goes to the CD and high to the bullets. The bullets could be wired in series or parallel just depends if you need more or less output from them, and what impedance the crossover is designed for. |
