Ultra compact mid/high |
Post Reply | Page <1234> |
Andylaser
Registered User Joined: 16 April 2010 Location: Southampton Status: Offline Points: 300 |
Cant go wrong with a Volt driver. Once experienced, never forgotten.
"music so loud, that if we move in next door to you; your lawn will die" - Lemmy
dlyxover
Old Croc Joined: 14 June 2007 Location: Liverpool Status: Offline Points: 1502 |
I did some 5" +1" coax cabs a while ago.
BMS loaded, I really like how they sound. Use them as monitions in the studio when tracking vocal and other quite instruments, they don't do much below 90Hz very crisp and detailed. |
In the Truth there is no news, and in the News there is no truth
JonB67
KWB75
Registered User Joined: 10 November 2007 Status: Offline Points: 259 |
Thanks all - I’ve asked Volt for a price, the CX220.1 sounds ideal.
Lucasdude
Young Croc Joined: 16 March 2013 Location: London Status: Online Points: 824 |
Blue Aran says £230 each For those.
KWB75
Hmm, £250 direct from Volt - no availability until mid August!
Back to the drawing board…
markie
Old Croc Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4570 |
I have a couple of pairs of Tannoy i8s, also the controller (TX1) which can be used as a crossover to separate sub, or an eq for full range use.
PM me if any interest.
Lucasdude
A bit leftfield, but depending on how loud you need it to be you might be able to find a good deal on some car audio coax speakers. The stated power handling obviously needs to be taken with a bucket of salt, but I've had some pretty loud and great sounding ones from Infinity and Focal in the past.
al_x
Young Croc Joined: 12 February 2006 Status: Offline Points: 834 |
I’ve been eyeing up this 6” P-Audio coaxial for a compact 12v rig. It seems to tick all the boxes of my needs, which sound similar to yours.
Edited by al_x - 20 April 2022 at 8:10pm |
Xoc1
Registered User Joined: 15 October 2012 Location: Devon UK Status: Offline Points: 397 |
Space - The final frontier. The challenge being what are you going to compromise - Efficency vs. bandwidth. So deciding factor might be how low vs. how loud. Some drivers like being in a small a box as possible - This makes the natural roll off steeper, but flatter in the pass band. Useful for drivers with a small x-max. But crossover frequency will be fairly high. Lots of mid drivers have a decent x-max- This makes them more suitable for use with reflex ports which can extend the bandwidth while still giving resonable efficiency. I am thinking of allignments like QB5 where the port hump is actively filtered to give an extended response without too much excursion. Time spent with Hornresp can give interesting results - Driver in reflex cab, run sim and then use the filter wizard to check the response & displacement.
IanD
Registered User Joined: 17 January 2009 Location: London Status: Offline Points: 400 |
Not coax, but the B&C 6MBX44 mid-bass driver in a 3l reflex box tuned to 120Hz handles 200W continuous and is about 96dB/W. About £120 each though, so might be out of your budget...
LjudLahger
Young Croc Joined: 31 July 2008 Location: Sweden Status: Offline Points: 838 |
I had those and I thought they was too heavy. Seen a German page where the basket snap of this reason, and thats in a "hifi" cab under transport, so just a warning there...
