Ultra compact mid/high |
Post Reply | Page 123 4> |
KWB75
Registered User Joined: 10 November 2007 Status: Offline Points: 259 |
Posted: 09 April 2022 at 1:42pm |
After some suggestions for a very compact mid/high/full range to pole mount above a 12” sub - this is for house party/background music so looking for sound quality over spl.
Thinking along the lines of a 6.5” + comp or tweeter, the original top for the sub was a 6 x 3”, but I’m not so keen on building similar. Happy to build or buy used, budget is c£150 Thanks!
APC321
Young Croc Joined: 24 August 2013 Location: West Midlands Status: Offline Points: 680 |
For the best sound quality close up I have always favoured coaxial drivers.
A very compact solution too. I think that you can definitely hear the advantages of "point-sourceness" of this type of driver up to maybe 3m away, so would be good for a house party. Especially as you are using a separate sub, so lower frequencies are not modulating the hf. Maybe something along the lines of a CVA One Voice OV8 or Tannoy I8, or something a bit smaller based around a 6.5" driver as you say. With a budget of £150 and a bit of hunting around you might find something on the secondhand market, generally where the seller is offering local pick-up only, as that is where there bargains are to be had. Edited by APC321 - 10 April 2022 at 11:47am |
Robbo
Old Croc Joined: 05 December 2005 Location: Shropshire Status: Offline Points: 4221 |
Keep your eyes on Ebay for some of the Martin Audio EM Series of cabinets---They come up regular and the smaller models very often go quite cheap as they are install series in green colour---a quick coat of black paint and stick a Top Hat in the bottom and you are sorted----and they also sound quite nice as well.
markie
Old Croc Joined: 31 October 2005 Location: Sunny Liskeard. Status: Offline Points: 4570 |
Last year I built a box with 2 x Faital Pro 6FE100s in. I used a large format piezzo driver simply to try it and was very impressed with the results........ ended up leaving the piezzo where it was.
KWB75
Thanks all - think I’m going to go down the DIY route…
I had a look through some old posts on here - is the BMS 4524 still regarded as the best budget compression driver? Also, would this be overkill on the HF if paired with a 6.5” LF driver? Thanks!
KWB75
Forgot to mention, I haven’t ruled out the coaxial route, any suggestions for nice sounding small coax?
The Oberton 8CX is only £100 at the moment, anyone have experience of that driver? Thanks again!
toastyghost
https://voltloudspeakers.co.uk/loudspeakers/cx2201/
If you favour sound quality, then these are a great option. Cheaper than you'd think too. Blue Aran used to sell them, but it seems they may have changed distributors. You can always call Volt directly to be pointed in the right direction. Make sure you use a grille to protect the soft dome from prying fingers if they're going to be near people at a house party. Ideally, you want a relatively fine/open mesh and foam to avoid impact on the HF extension. |
KWB75
Yeah, I do like the sound of the volt - heard some good things about it. Might be just above budget, but I guess I need to factor in that it comes with a decent crossover too.
Whilst not in the same league as the volt, I’m half tempted to give the Lavoce CSF061.21 a whirl for <£30. |
markie
I have raved about the VOLTs many times on here.
20 litre cab, 68mm vent 125mm long, will give flat response to 57Hz, -3dB point of 50Hz. You might decide you don't even need a sub.
snowflake
fane sovereign 12-250tc is another cheap option. there's a long thread about them.
Meat Substitute
Registered User Joined: 10 July 2020 Status: Offline Points: 79 |
I like Volts and still have a pair of FR220s I use for house parties and the like. They're good but definitely not the last word in speakers. Some of the normal (not coaxial) ones are much better and can sound awesome when implemented well. My mate who's been bmuch more active than me on the building lately has been raving about the BMS 5N160. Based on the graphs he's sent me it looks pretty darn good and he's using it with a 10" sub so might fit your use..? |
JonB67
There was a thread on here years ago using that driver and second bms non coax driver in a tiny box. Was always intrigued by how much useable coverage and output you would actually get from it. More than its size suggests I expect.
