  New Posts New Posts RSS Feed - Understanding these Turbosound TQ440 EQ settings
al_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote al_x Quote  Post ReplyReply Direct Link To This Post Topic: Understanding these Turbosound TQ440 EQ settings
    Posted: 18 July 2022 at 5:24pm
We have some Turbosound TQ440 and as far as I know these are recommended EQ settings. Trouble is I don’t know what it means. Could someone translate into a simpler format? Cheers
12 0 + 0.125 30Hz ** 1.31kHz * Auto (-1dB) -***@405Hz (Q=3),
-***@721Hz (Q=3)
6.5" + 1" -2 + 0.000 1.31kHz * 22kHz Auto (-1dB) -***@1.71kHz
(Q=1.7), -***@4.08kHz (Q=2.5), +***@10.5kHz (Q=2.0)
nojunk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nojunk Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2022 at 6:54pm
the 12" section (low) shall be 0db, polatity in phase (+), delayed by 0,125 ms to the mid/high unit, HP shall be 30Hz, LP shall be 1310Hz, additional EQ @405Hz -1.8dB (Q=3), and @721Hz -3.0dB (Q=3).
the 6.5"+1" section (midhigh) shall be -2db, polatity in phase (+), HP shall be 1310Hz, LP shall be 22KHz, additional EQ @1.71kHz -5.3dB (Q=1.7), @4.08kHz -2.2dB (Q=2.5) and @10.5kHz +2.2dB (Q=2.0).
hth
al_x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote al_x Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2022 at 10:45pm
Thanks, that makes a lot more sense.
Clap
4D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4D Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2022 at 11:10am
No mention of crossover slopes..
Convention would suggest
Hi pass But24
Lo pass LR24
Post Options Post Options   Thanks (0) Thanks(0)   Quote nojunk Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2022 at 5:09pm
Hi pass But24
Lo pass LR24
just check the dsp3.4 version (my last one):  HP 30Hz is 18db BW, LP/HP 1310Hz 24db LR
lickweed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lickweed Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2022 at 6:10pm
30hz thats rather low for 12"
http://www.liquidsound.co.uk/
Peter Jan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter Jan Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2022 at 7:04pm
30 Hz seems low, but it is meant to be a fullrange cab on it's own too.
With additional sub, highpass can go up to 60-70-80 Hz or so.
Post Options Post Options   Thanks (0) Thanks(0)   Quote nojunk Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2022 at 8:16pm
with the original TQ-425 (2x 15") sub, the TQ440's HP is moved to 125Hz AND reverse polarity on 12" as well as 6.5"+1".
This page was generated in 0.265 seconds.
