  New Posts New Posts RSS Feed - Unity horn build
Unity horn build
 Post Reply Post Reply Page  <12345 9>
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 14 March 2013 at 1:39pm
seems i'm suffering from something called high frequency fingering Shocked due to incorrect horn termination Big smile
CoblosBrengose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CoblosBrengose Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2013 at 7:05am
congrats snowflake
my project stage: drawing board Cry
drawing board
4AC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 4AC Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2013 at 10:45am
Wow very nice job on the Unity horns in Sketchup!
Would you be so kind to share the sketchup model with us?
You can upload/export it to the sketchup models database...
Cheers
uǝɿɿɐʌǝ6ɯo sı ʇsʞǝʇ ǝzǝp
bitSmasher View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote bitSmasher Quote  Post ReplyReply Direct Link To This Post Posted: 15 March 2013 at 11:09am
oh my LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote CoblosBrengose Quote  Post ReplyReply Direct Link To This Post Posted: 16 March 2013 at 2:20am
hi A4C
that's only artistic depiction of my imagination based on the published photo on the DSL website, not a  scientific / accurate model. the internal geometry of synergy horn is kinda mystery to me. I'm still learning to grasp it.
Phil B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil B Quote  Post ReplyReply Direct Link To This Post Posted: 17 March 2013 at 1:25am
Originally posted by CoblosBrengose CoblosBrengose wrote:
congrats snowflake
drawing board
Snap....
http://www.facebook.com/photo.php?fbid=600245400004843&set=o.126113687424773&type=1&theater
Are you trying to back engineer from that photo?
.p.
Edited by Phil B - 17 March 2013 at 1:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CoblosBrengose Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2013 at 2:57am
Hi Phil
my drawing came first, I posted in diyaudio forum subwoofer section to illustrate 30 hz 6-fold TH designed by XOC1 in the March 12, and Ivan Beaver, the DSL lead engineer, released few days later on FB, March 15.  I have purchased 8 Faital 12" few weeks ago.
he use SH69 while my drawing is SH46-wannabe, which is narrower to allow 4 boxes to cover 180 deg.
I must admit Mr. Danley is genius! the more I dug the more respect, how thoughtful his design is.
Edited by CoblosBrengose - 18 March 2013 at 3:02am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phil B Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2013 at 7:20am
Well here`s some more motivation for you.... we got busy today with our new prototype 3 way Unity...after doing a lot of reading and sims. It is a juggling act with Unities, whatever you do somewhere affects further down the chain. So after doing our mids we are hopefull we got the low mids right!
http://forum.speakerplans.com/topic63191_post763223.html#763223
.p.
Steve_B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve_B Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2013 at 1:58pm
Do you have any polar or on/off axis plots? I'm just curious how bad it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 18 March 2013 at 4:41pm
haven't got any plots but if i remember correctly was about 4dB dip about half an octave wide centred on 3.5kHz. clearly audible as you move from on-axis to off-axis. think I'm going to do a new prototype with bigger mouth and 60V*45H dispersion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve_B Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2013 at 11:36am
The generally accepted principle is to double the flare rate over the last 1/3 of the horn. The following diagram is taken from Keele's paper on constant directivity horns.
bwaslo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bwaslo Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2013 at 2:22pm
I ran into a similar dip on-axis on my 90x60 DIY Synergies.  I'm pretty sure it was coming from diffraction off the larger ports (nearly went away when I blocked the ports with thick plastic tape).
http://www.diygroup.com/forum/index.php?topic=19.msg895#msg895 - http://www.diysoundgroup.com/forum/index.php?topic=19.msg895#msg895
Edited by bwaslo - 20 March 2013 at 2:24pm
