Unity horn build |
Page <1 56789> |
snowflake ![]() Old Croc ![]() Joined: 29 December 2004 Location: Bristol Status: Offline Points: 3097 |
by the way, Phil, hear you were at the Combat Wombat gig at my local in Bristol a few months ago. Think you were chatting with my friend Nate from Kebele Sound LOL
crossover finished
![]() the resistors are rated at 30W each without a heatsink - may upgrade to some that are 50W or use even 6*50W so that the L-pad can dissipate a full 300W when the driver+bulb is drawing 100W - but maybe this is overdoing it when duty cycle and thermal mass of the resistors is considered??? also just received pre-wound coil that looks a bit tidier than my attempt. haven't got any LPF on the mids as this gives flatter response at 4kHz for some reason- perhaps coupling between mids and tweeter compensating for the hf 'suckout' of the mid ports. bi-amped with the woofers on one channel and mids/high on other channel. active 3rd order LPF at 130Hz and HPF at 280Hz with the phase of the mid/high section reversed gives flattest response. been running it off a crown xe4000 which can put 1200W into 4R for the woofers and 800W into the mids. haven't got it near clipping yet as the whole house starts vibrating ![]() ![]() Edited by snowflake - 27 February 2014 at 6:29pm |
jamieb ![]() Registered User ![]() Joined: 05 December 2012 Location: male Status: Offline Points: 64 |
I'd love to hear it
Phil B ![]() Old Croc ![]() ![]() Joined: 21 November 2004 Location: Melbourne Status: Offline Points: 2313 |
I was.... very briefly ! Managed to cobble together an almost OK sounding rig out of what was in the pub ( and what I made them go fetch !). Monkey Marc from Combat W is one of the other bods involved with our Solar/ Wind rig... Glad to see your project ticking along. We have been running our 3 way Unities for a few months now and all we get is compliments about the sound. We did a small stage at an outdoor festival on New Years day and pretty much wowed everyone there ( so much so we dragged it to the VIP area and did a 2 day after party!). I can`t explain to people how good they sound and the way a Unity horn images a true point source...you have to hear it ! The main stages had ground stacked L`Acoustic Kudo with SB28 subs and sounded horrible.... maybe we should offer to do it next year ! We are still running our mid/high crossover with a simple HPF for the Highs and no LPF for the mids like yours, but everything else is through the Ultradrive . The next step is a better crossover ( hopefully a BSS388 I have my eye on! ) and then maybe some 18" tapped subs with barn doors for next year ! Along with an MPPT controller for the wind genny! It`s never finished ........ .p. |
fat_brstd ![]() Old Croc ![]() Joined: 23 August 2008 Location: Melbourne, OZ Status: Offline Points: 2112 |
I'll have one of your ultradrives if your getting rid of them. HAHA. BTW Snowflake, those unitys look really nice. Very good work. I also second what Phil said about not really being able to explain their coherence and having to hear them for yourself as nothing else comes anywhere near as close to a true point source, its actually quite strange to listen to the first time as you swear your hearing it wrong, or at least thats what happened to me. |
Melbournes Rootical Warrior Roots - Dub - Steppers facebook page |
finished crossover at last after late delivery of capacitors and two wrong deliveries of heat-sinks. same as the one posted above but better components and a lot neater.
![]() had to mount the L-pad heat-sink separate to the rest of the crossover because of lack of space. connector strip is rated 41A with wire protectors under the screws. four more to make now :)
TONY.A.S.S. ![]() Old Croc ![]() Joined: 21 February 2007 Location: United Kingdom Status: Offline Points: 6878 |
It's quite time consuming isn't it.
billy.jukes ![]() New Member ![]() Joined: 31 January 2015 Location: Southampton Status: Offline Points: 8 |
Hello Phil,
Do you still have this old synergy horn? I'm developing my own and would love to hear it. I also live in Bristol. Cheers,
Hi, yes could meet up. you got a van and somewhere good to listen to them?
I could try and sort out using the malcom x for a listen. How many do you have and what do you have to fill the lf range?
I'll try and get my hands on a c7 rig as a reference point aswell
yeah Malcolm X if you can swing it - going there tonight as it happens. Can probably get in the Black Swan if not. Only got a pair of tops loaded up at the moment and 4*18" tapped horns.
Page <1 56789> |
