  New Posts New Posts RSS Feed - Unity horn build
Unity horn build
 Post Reply Post Reply Page  <1 678
snowflake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 11 August 2019 at 11:48am
old crossover left, new version right (designed with more accurate REW data). HPF shifted up to 1.5kHz and changed to second order rather than third (plus polarity reversal on tweeter). got rid of bulb and high-shelf bypass cap - rather implement these in LMS. series resistor and PTC moved to amp-side of filter inductor to protect whole circuit from over-powering. large cap is DC blocking and signal for both 6" and 1.4" now goes through it. same resistor network used as previously posted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 11 August 2019 at 12:54pm
is coil too close to the tweeter? it is 3.3mH (though measures only 2.9mH). it's a neo tweeter.
odc04r View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 12 August 2019 at 11:57am
I wouldn't have thought that the coil's field would significantly affect the presumably much more intense field in the tweeters gap. What average current do you estimate the coil is seeing during typical use? The majority of a coil's magnetic field is inside it along the central axis, outside field strength is weak in comparison.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 12 August 2019 at 12:22pm
without digging out old Akabak model (and old computer to run it) I am not sure. would the peak current through the coil be at the crossover frequency? and equal to the current through the driver? so about 1.5A max and much less at other frequencies.
Edited by snowflake - 12 August 2019 at 12:25pm
studio45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote studio45 Quote  Post ReplyReply Direct Link To This Post Posted: 12 August 2019 at 1:04pm
 As I see it, with the two components in the orientation shown, the tweeter's external field lines will be parallel to the mounting board, while the coil's will be perpendicular. So they are not particularly well set up to couple.
There may be a very small modulation of the tweeter's magnetic field, and the coil will experience some mechanical forces as current passes through it - this will probably introduce a minor amount of distortion, but likely at a level far below other sources of distortion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 12 August 2019 at 1:13pm
Yup I agree with that assessment.
I usually model xovers in Spice as well as Akabak if I'm trying to integrate them fully into a design. Spice is so much better for estimates of power dissipation as a function of frequency etc and I find helps when sanity checking.
Peak current through the coil is going to depend on a few factors including musical content and the crossover design. Hard to say.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 19 August 2019 at 11:39am
measurements of old vs new crossover. on axis and 25 degrees off axis. old: green and blue, new: red and orange. smoothed 1/3 octave. ignore below 400Hz as measured in small room due to rain.
much improved. mid-range lobbing isn't too extreme and expected high-frequency fingering above 3kHz is acceptable. I was having to do quite a lot of corrective eq with the old crossover (obviously too much vocal). with the new crossover it sounds pretty nice with no eq at all.
next will try and play around with splay angles.
see below for response plot
Edited by snowflake - 19 August 2019 at 6:31pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 19 August 2019 at 12:46pm
Yep, nicely damped the peak at 1KHz, much smoother roll off now and aintegrates well with the top. Hows' the phase looking?
I'm still extremely keen to build a pair of Unitys but being realistic it's going to be years before I get to the final and finished items. But I can start with the mid/high portion of the design. I'm considering 3D printing the horn/mid assembly and then integrating that with a wooden cabinet with the low mids.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 19 August 2019 at 1:54pm
if you can 3d print the tweeter and mid mountings it will save a lot of woodwork and allow you to play around with chamber volumes and port shapes that just weren't practical with a router and rail saw.
PM me if you want the CAD drawings of what I built as a starting point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowflake Quote  Post ReplyReply Direct Link To This Post Posted: 19 August 2019 at 2:03pm
forgot to switch on the active filter - 3rd order LP and HP @350Hz. mid/top output inverted and delayed 33cm
phase (old green, new red)
group delay
Edited by snowflake - 19 August 2019 at 2:34pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote odc04r Quote  Post ReplyReply Direct Link To This Post Posted: 19 August 2019 at 10:10pm
That was my thinking, good for prototyping. I was also wondering if extending the port length to the mid chambers such that they were time aligned to the HF diaphragm could be of any practical value.
Cheers for the CAD offer, maybe sometime in the future. I've already spent a while trying to flatten 3D CAD models of Unity horns into sheets for cutting - it's surprisingly non trivial. Not a typical use of CAD but there are ways.
The plan in the meantime is to upgrade the CNC to a 4x2 ft bed and then I can just run the sheets off and finish them with a table saw to give near perfect results with minimum effort. It's not strictly needed but I'm going to do it anyway so why not use it.
No obvious discontinuities in the phase with either xover but the newer does appear to have a more linear slope up to 2k so hopefully that leads to better mid-tweeter integration
