Unloaded amp to set limiter |
MadPsy
New Member Joined: 16 February 2022 Status: Offline Points: 3 |
Posted: 16 February 2022 at 1:54pm |
I'm hoping this is a binary answer rather than 'it depends' but here goes.. Is it plausible to run an amp unloaded for the purpose of setting a sensible level for a limiter. In other words would one expect an amp to clip at the same input level reguardless if it's loaded down or not (assume power supply has plenty current available)? I suspect it might not be as simple as this so curious what other think. |
toastyghost
Yes, if you base the limiter value on the measured voltage at the amplifier output terminals - which handily, also happens to be how loudspeaker power ratings are calculated.
MadPsy
Aha yes indeed. I should have clarified in the question I meant using the amplifier's level indicator directly (rather than a DMM on the output). In other words I'm unsure if you should expect the level indicators to change when there's a load vs no load. In this case it's MC2 amps.
