  New Posts New Posts RSS Feed - Unnamed Design by Lutkeveld (Development Thread)
 Post Reply Post Reply Page  <12345 8>
carlosdelondres View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carlosdelondres Quote  Post ReplyReply Direct Link To This Post Posted: 01 November 2017 at 9:01am
Is the battery board a balance charger as well?
lutkeveld View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lutkeveld Quote  Post ReplyReply Direct Link To This Post Posted: 01 November 2017 at 9:23am
Yes sir, you connect a series charger and the board does the rest. Really a plug and play system. No soldering required. Batteries go in like this:
More details on the battery management system here:
http://www.ti.com/lit/ds/symlink/bq76925.pdf
Padde298 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Padde298 Quote  Post ReplyReply Direct Link To This Post Posted: 01 November 2017 at 10:26am
Thumbs Up
I like it more and more!!!
LOUDER!!! MO BASS
Shortrope View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Shortrope Quote  Post ReplyReply Direct Link To This Post Posted: 01 November 2017 at 5:00pm
Excellent...look forward to the finished product.
Post Options Post Options   Thanks (0) Thanks(0)   Quote carlosdelondres Quote  Post ReplyReply Direct Link To This Post Posted: 01 November 2017 at 7:36pm
Looks great, I assume it will be easy to parallel multiple boards? Been looking for something like this that can handle 6S :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote lutkeveld Quote  Post ReplyReply Direct Link To This Post Posted: 01 November 2017 at 9:25pm
Yes, you can wire multiple boards in parallel or even stack them for increased capacity
Post Options Post Options   Thanks (0) Thanks(0)   Quote lutkeveld Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2017 at 9:53pm
Small update:
Still have not send out the next revision. Found some issues and points of improvements. Improved:
-More efficient (synchronous) DC-DC converter
-Added power switch for the amplifier, shutdown current was too high (200uA)
-Added zeners to protect the mosfets from blowing up on 20V+
-Added reverse polarity protection
-Fixed issue with stacking, making it easier but limiting it to 4 channels total
Here a cool render for in the meantime. New PCBs should arrive within 2 weeks:
Hemisphere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hemisphere Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2017 at 10:16pm
Great to hear this project is still moving along. Looks tiny!
Phase 1: Post on Speakerplans
Phase 2: ?????
Phase 3: Profit!
Post Options Post Options   Thanks (0) Thanks(0)   Quote lutkeveld Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2017 at 10:24pm
62x36mm! Smaller than a credit card.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hemisphere Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2017 at 10:31pm
Perhaps you could call it Cardioid Approve
.. Actually that's a lot smaller than a credit card. Less than 2/3.
There's gotta be a better standardised object to compare it to.
A playing card is 2.5" across or 63.5mm so that would be a good reference for scale.
Edited by Hemisphere - 27 November 2017 at 10:43pm
Phase 2: ?????
Phase 3: Profit!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Padde298 Quote  Post ReplyReply Direct Link To This Post Posted: 28 November 2017 at 9:19am
 ShockedShockedShocked
WHAT..? 62x36 mm, and you still have all this..:
-Onboard programmable DSP
-high power class D amplifier
-Bluetooth 3.0
-Microcontroller for all kinds of tasks
Based on:
-TAS5754M: 2x50W max class D amplifier with onboard programmable DSP with functions like dynamic bass boost, psycho acoustic bass enhancement, softclipping, dynamic range limiting and 5 biquads per channel
Let me know when ordering is possible! ClapClapClapClap
LOUDER!!! MO BASS
Post Options Post Options   Thanks (0) Thanks(0)   Quote lutkeveld Quote  Post ReplyReply Direct Link To This Post Posted: 08 December 2017 at 2:00pm
New PCBs arrive 12 december. I really hope that the PCBs will pass compliance testing with the FB filter, an LC filter would be much bigger and more expensive. Maybe if they don't pass I will still sell those 8 pieces for the DIY market, they would still work well but just not within the strict limits of the CE/FCC.
